Acuralink Setup with Blackberry on Verizon Wireless Network...need help.
This has been annoying me since I bought my TL. I cannot seem to get my Blackberry Storm to work with Acuralink (Verizon Wireless). Here's what's happening:
1- I go to Phone Setup
2- A screen pops up to select your network
3- I select Verizon
4- The system takes me right back to the network selection screen.
What gives?
BTW, I do have a data plan on my Blackberry.
3- I select Verizon
What gives?
'08 Type S KBP
Acuralink works with my BB Pearl on verizon. Try deleting the setting and selecting easy setup again and look at your phone. The handsfree should disconnect and you should see "Modem Mode Enabled" displayed on the phone.
I had the same problem and tried the easy setup a few times and it finally started working.
I believe you have to have the teathering plan, which is seperate from just a data plan. I get mine to connect, but i'm not sure what to do from there? When I do easy setup, it says connected successfully and just goes away.
08_UA7_Gr33k
02-11-2016 02:17 PM
AcuraKidd
09-25-2015 11:18 PM
