Acura TL 2006 iSimple
Guys
I have installed the I-Simple Ipod integrated solution in my TL. However I changed phones now and got a S3. Is there jack that I can use for integrating the S3 to the I-Simple.
what are my other options? Any suggestions would be greatly appreciated.
If he had someone else install it maybe they didn't put the cable in? It comes with two cables- an iphone 30 pin cable and a combo rca/headphone type plug. The headphone plug will work with the s3, but you'll lose the steering wheel controls and text display.
isimple sells a blustream unit that will stream audio over blue tooth and you retain text and wheel controls if that's a big deal.
06, 2006, acura, audio, car, compatible, connected, install, installing, isimple, message, simple, siteacuraclcom, text, tl
