Acura TL 2004 CarPc "WorkLog"
Old May 9, 2008 | 11:48 AM
  #41
King of Pain's Avatar
My first dynamix was bad too. I am going one 1 year on my second with no problems. It's big, 8" and 16:9 widescreen, but I would like it to be brighter. Once it goes bad I may look to another brand.
Maharajamd:
My schematic is almost the similar as yours except I have high end sound card that gives me RCAs out. I tapped into the XM receiver in the trunk. When I press XM on my head unit I get the PC sound. I still retain all stock head unit functions. Sorry, I use Roadrunner too.
Old May 9, 2008 | 11:50 AM
  #42
Originally Posted by VmtSquad
What is the S.B.L 5.1 USB device?? I was planing on using the Car2PC thing but Im sure that I will have to go will another device to get the 5.1 to run perfectly!!
VmtSquad
I think it's a USB soundblaster live soundcard
Old May 9, 2008 | 12:48 PM
  #43
maharajamd's Avatar
^ Yup, it is. I used a laptop obviously, so super high end audio cards were not an option. Everyone on mp3car said just use a regular old SB Live usb card. It was only like $40...
No center speaker because that schematic is for a 93 prelude, not a TL
As far as Centrafuse is, I wouldn't fathom using anything else. I tried them all, and centrafuse was by far the best. Of course it isn't shareware so...it's not free. :P I had it all working, video, audio, gps, wifi, traffic, even had some of the engine management working too...well as much as I could with OBDI...
The only thing I could complain about was the screen. It was just a lcd, not a anti-reflective like the oem nav screen or higher end lcd's are. So glare was an issue. Well, until I got tinted
I had a script setup so when my car came into my houses wifi area, it would join the network, check my "music folder" and whatever songs I had in there, it would copy over and load into centrafuse. All I had to do to put new material on the carpc was drag songs into a folder on my home desktop Can't possibly explain how nice that was.
Old May 9, 2008 | 03:54 PM
  #44
I'm using the EMU 0404 Sound card, not super high end but good output and clean sound. My CarPC is set up for wifi too. I can copy stuff over from my home network into my car, look at weather and traffic b4 I leave for work.
Old May 11, 2008 | 11:03 PM
  #45
VmtSquad's Avatar
"Advance"
Whats up guys!! Finally took some time to get some pictures tonight. My project is now growing up.........
Here was the first step, removing the extra plastic on the bezel.
Second step was to apply some Epoxy Dynatron 660 to fit the bezel as I WISH!
Results after a couple hours sanding and fiting **NEW DIGITALFX3.0***
I still need to sand and fill the holes but its only some last details thing. Then I'll simply bring it to a painter and he will give the OEM look back again lol :P
So I said that my project was growing up, here's what I mean.
Im taking the mould of my glove box (custom case)
I calculate everything and I finally choose to build my comp in my GloveBox.For that, I need a case, so I decided to build one with the Dynatron 660, so it will be made of plastic and some reinforcement. I'll have to sand it so it will be soft and will fit perfectly. I plan on making this removable (not portable)....its all on the planing board
!More to come!
Old May 12, 2008 | 01:01 AM
  #46
ezland00's Avatar
thanks for the upgrade. everyting look great so far. i am also planning to install a carputer in my car, so i guess i'll just copy what you are doing. however i'll just use a laptop so i don't have to worry about building a computer in glovebox.
So the LCD screen will not fit right without reshaping it? Will the navigation brezel fit correctly without all the cutting and reshaping?
Old May 12, 2008 | 07:08 AM
  #47
VmtSquad's Avatar
"Advance"
It'll fit but, you still see some parts of the screen on both sides. I wanted to hide those parts and also placed the screen 1/2 inch deeper in the dash to minimize the light during the day. Works pretty good so far!!
As for the NAVI bezel, I think it's better then the stock one, but it can't be perfect. Let us know if you FIND one as they are really rare and only come with the NAVI screen, which is really expensive.
Will post pictures when Bezel and Case are ready! Stay tuned!
VmtSquad
Old May 13, 2008 | 08:45 AM
  #48
maharajamd's Avatar
You're taking the bezel to a painter to get painted?!?! IT should be very easy to do yourself...
sand, primer, sand, primer, sand, base, sand, base...
I found that regular black paint doesn't look right. Honda black interior have this semi-gloss off black color to them. So if you spray semi-gloss or gloss black, it'll look way too dark. If you use flat it'll look cheap.
I found that the dupount trim paint looks just about spot on. The problem is the way it sprays. It sprays in a very funky pattern. When I did this process for the prelude I probably painted/sanded/repainted 8 or 10 times...
Old May 13, 2008 | 11:53 AM
  #49
VmtSquad's Avatar
"Advance"
I know I could get a could result by myself, but the problem is the time!!! I really want to have this installed and fullly working for mid June. So I will bring this to a friend who know how to work plastic and paint, it'll take him couple hours instead of couples days for me !!
Thanks for the inside!!
VmtSquad
Old May 13, 2008 | 12:50 PM
  #50
maharajamd's Avatar
^ Heh, having connections is nice isn't it? :P
Good luck, can't wait to see the finished product.
Have any plans for a hidden keyboard or track pad anywhere?
Old May 13, 2008 | 01:10 PM
  #51
VmtSquad's Avatar
"Advance"
For sure its good to have connections, simply need to know how to use them.
Here is the keyboard I bought, its made for the PlayStation 2. Seems to work well with all kinds of computers and operating systems....
http://store.mp3car.com/Mini_Key_USB..._p/com-005.htm
Here's the one for PS3...
http://www.ps3fanboy.com/2007/04/24/...n-my-keyboard/
Old May 13, 2008 | 03:26 PM
  #52
maharajamd's Avatar
^ Not bad. I bought one of those flexible ones...
I have heard that logitech makes one thats about what u posted above but it also has a mousepad (like a laptops) on it as well...
Old May 13, 2008 | 10:26 PM
  #53
VmtSquad's Avatar
"Advance"
ya the dinovo mini its nice but a bit expensive for the task, my skin is good for that
Old May 21, 2008 | 01:04 PM
  #54
o4Komodo's Avatar
Rev High; Drive Happy
Any updates? =]
Old May 24, 2008 | 07:53 PM
  #55
VmtSquad's Avatar
"Advance"
Hey guys,
A Quick update before the major install tomorrow! I just had some time to finish my bezel, it looks really clean and I cant believe its finally done lol
Primer - 3rd coat!!
Final Paint - 3rd coat!!!
Its not PERFECT but it really look good in the car
more updates coming soon!!
Vmt
Old May 24, 2008 | 10:58 PM
  #56
That came out pretty good. Can't wait to see it installed.
Old May 25, 2008 | 02:38 PM
  #57
o4Komodo's Avatar
Looking good! Seems like you are almost done
Old May 26, 2008 | 09:25 AM
  #58
VmtSquad's Avatar
"Advance"
Yeah almost done, I installed everything yesterday from 11AM to 11PM .
Its on a temporary install for now since I was missing some wiring and extension. I placed the computer below the passenger carpet. I tested every single features and they're all working like a charm....
I'll post some pictures of the final install later on next week. My car is at the dealer for repair as I was a victim of a hit and run!!!
Stay tuned!
Vmt
Old May 26, 2008 | 09:52 AM
  #59
VmtSquad's Avatar
"Advance"
What's left:
1) Run 12v wire from battery to the trunk
2) Connect OPUS 150W on Ignition and 12v + test Hibernation
3) Rune wire extension for USB, audio jack and VGA
4) Run GPS antenna on rear deck (below carpet)
5) Mount Case in the trunk
6) install USB DVD in GloveBox PS2 slim
Old May 28, 2008 | 11:46 AM
  #60
maharajamd's Avatar
Hey, you painted it yourself? Thought you where taking it somewhere....
What paints did you use? Looks great!
Old May 28, 2008 | 03:11 PM
  #61
cgacutl's Avatar
Another DESI Acurziner
Cant wait to see the final write up....
Old May 28, 2008 | 03:34 PM
  #62
Blazing GT's Avatar
Great
I always wanted to do this mod since i have no navigation
Old May 28, 2008 | 03:40 PM
  #63
VmtSquad's Avatar
"Advance"
Painting
Yeah I had some balls to try and it went pretty WELL!!
I asked a lot of question to the paint responsive at my corner paint store. He helped me understood what I had to do to make it look OEM.
I'll wright a simple DIY in my final right up next week, hoping it will help others!
***I used some red primer (3 coat total) + some FLAT BLACK ENAMEL (4 coats total). I think I will have to redo some more sanding and painting, to make it last!! and apply a transparent clear!! But I was in a hurry, so I took a shortcut
Vmt
Old May 29, 2008 | 12:18 PM
  #64
maharajamd's Avatar
^ Good. Told ya you could do it yourself
Old May 29, 2008 | 02:37 PM
  #65
VmtSquad's Avatar
"Advance"
Originally Posted by Blazing GT
Great
Go ahead, you won't regret it!!!!!
Vmt
Old May 30, 2008 | 09:49 PM
  #66
cgacutl's Avatar
Originally Posted by King of Pain
I am using the E-MU 0404 sound card. It has RCAs out. This is tapped into the XM input on the HU. So when I press the XM button I get the PC sound.
Here's a link to the card
http://www.emu.com/products/product....&product=10447
Does is mean you replaced the XM with PC sound? (pardon the stupid question)
Old May 30, 2008 | 11:08 PM
  #67
Yes.
There is a switch that can be made to toggle between the 2 but I just went ahead and disabled the XM since I really don't use it.
Old May 31, 2008 | 11:53 AM
  #68
VmtSquad's Avatar
"Advance"
I finally installed everything last sunday. Just got my car back from the dealer for the hit and run repair.
I still need to connect my OPUS 150 to the ignition, run some extension wire and place the computer in the trunk. Im basically on testing mode.
I had the chance to try the Car2Pc Device, but didnt had major luck with it. First when I started the car, I was able to switch from CD to PC and vice versa, but as soon as I stopped the car, I was loosing my display and wasnt able to switch between cd - PC again ???
I asked some questions yesterday and explain my situation to the responsive guy from car2pc. I hope I'll have some good help!!
Vmt
here'some pics of the 85% install
!!!OEM LOOK!!!
My DigitalFX3.0 modified splash screen
Playing around with theme
Old May 31, 2008 | 03:46 PM
  #69
cgacutl's Avatar
Did you move the stock radio / ac display lcd's to the bottom of the panel?
Can you also please let us know about the wiring challenges that you faced?
thanks
Old May 31, 2008 | 04:50 PM
  #70
VmtSquad's Avatar
"Advance"
^^ Yeah I did moved the HVAC display below the Head Unit, but I'll have to redo it, dust is getting into it.
As for the wiring challenges, I had it very easy for NOW lol.
To move down the display you need to extend ~40 wires. What I did is, bought a extra display from ebay ~ 30 bucks. I removed all female + male connectors from that extra display. And I simply soldered these to create a big extended wire. Here's a exemple:
So that way I didnt have to cut any wire in the car.
Still, I need to connect my Power supply OPUS 150 that has an ignition wire, so I could turn on and off the car without arming the PC. Here what's left:
What's left:
1) Run 12v wire from battery to the trunk - DONE
3) Rune wire extension for USB, audio jack and VGA - DONE
4) Run GPS antenna on rear deck (below carpet) - DONE
6) install USB DVD in GloveBox and PS2 slim
Old Jun 1, 2008 | 01:08 AM
  #71
RTLNOOBIE's Avatar
Vmtsquad:
did you run your sound from XM unit? if so, can you take a pic of it. what collor of wires you tap in. right now my xm button on my radio is not working some how it blow when i try to run the sound from it the first time, but im planing to get it working again some how so i can run my sound to xm radio.. thanks. any way the project looks good. keep it up.
Old Jun 1, 2008 | 01:12 AM
  #72
RTLNOOBIE's Avatar
doest it get good signal? i place mine there too, but it doesnt intercept any thing. so i place under the driver side panel.
Old Jun 1, 2008 | 02:55 PM
  #73
o4Komodo's Avatar
Originally Posted by RTLNOOBIE
Vmtsquad:
I don't think his car has XM.
VMT, I thought you were going to route the case to the glove compartment? Are you still making plans for that? Or was the trunk thing just temporary till the glove compartment mold is completed?
Old Jun 1, 2008 | 05:09 PM
  #74
VmtSquad's Avatar
"Advance"
^^ You got it right!
RTLNOOBIE : I don't have XM radio since my car is an 04 Canadian model. I only have the option of a AUXILIARY input. I just tried with the Car2PC device and I have some trouble making it work, so I'll probably try with another Aux input device.
Link : http://car2pc.com/
04Komodo: The glove box mold was a BIG project and I didn't want 2 wait. Its been more then a year of plan and config, it was about time to install.
I'll keep the glove box project for next winter.
I still have much to do to make it work and look as I want 2.
Old Jun 1, 2008 | 07:47 PM
  #75
o4Komodo's Avatar
Oh, I see. Well, atleast you got it up! And winter projects are always great! Especially with how long our winters are....... that's like half the year lol.
Old Jun 2, 2008 | 08:02 AM
  #76
RTLNOOBIE's Avatar
i see, i use the tape player to get my sound from the pc and it has a lot of noise. my xm dont work i read some where says there fuse for xm but i can't find it anywhere in the car. and i dont see how i use auxiliary input in the stock deck. we have indash cd changer. divce says we can connect it to the cd changer. do I splice and tap the wire into the cd change? i wonder.
Old Jun 2, 2008 | 09:16 AM
  #77
ezland00's Avatar
nice work!!!
Does anyone know the part number for the HAC plugs? I also need to extend the the wire, but don't want to cut the stock wires.
Old Jun 3, 2008 | 10:39 AM
  #78
VmtSquad's Avatar
"Advance"
^^ You better look on ebay, unless you want to pay more then 250$
EDIT:acuraoemparts
Old Jun 4, 2008 | 02:13 PM
  #79
o4Komodo's Avatar
Is the sound quality on your carpc just as good as the stock cd player?
Old Jun 4, 2008 | 02:27 PM
  #80
VmtSquad's Avatar
"Advance"
For now, I'm not getting any sound since I unplugged the Car2PC device. I sent a support request and they sent me some things to test and debug.
I'll do what they want and send them the logs file. I will keep you guys updated on the development.
As for the sound, when I first installed the car2pc device the sound was good enough. I had the 5 speakers + subs running perfectly. I found that the sound quality was more depending on the SONG and PC audio card.
Vmt
