AcuraZine - Acura Enthusiast Community (https://acurazine.com/forums/)
-   3G TL Audio, Bluetooth, Electronics & Navigation (https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/)
-   -   Access Navi code 5 digits long please help!!!!!!!! (https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/access-navi-code-5-digits-long-please-help-842588/)
TLmalloy Dec 26, 2011 12:23 PM
I recently disconnected my battery cable and it says i need an access code, so i went on acuras page and got the code. They gave me a 5 digit code, but it will only let me put in 4 digits what should i do?
Trunk Monkey Dec 26, 2011 12:28 PM
Radio Code is 5 numbers
Nav Code is 4 numbers
TLmalloy Dec 26, 2011 12:41 PM
Yeah i know that. I looked at the sticker and i put the 4 digit code in and it says its incorrect
TLmalloy Dec 26, 2011 12:46 PM
42556
1987
it said this is my code when i put the navi serial number on acuras website? I tried putting in the 4 digit and it didnt work. it also said my radio one is 25421. Is there any way i can skip the navi one and try the radio code to unlock the radio?
Trunk Monkey Dec 26, 2011 01:09 PM
I don't exactly know what you're doing here and why this isn't working...but the radio is put in with the 1-6 numbers near the cassete deck. The Nav (4 digit code) is put in on the nav screen. If it's not going....you've got the wrong number
TLmalloy Dec 26, 2011 01:25 PM
I dont see how i have the wrong numbers if i found all the numbers on the side of the glove box, and i got the same numbers from acuras website and it still says its wrong!!
KN_TL Dec 26, 2011 02:12 PM
Radio and Navi are totally separate systems. You should be able to enter the radio codes to get the radio going (entered via the preset buttons on the radio).
It's also possible that the deck was replaced. Pull it out of the trunk to see if the serial numbers match.
TLmalloy Dec 26, 2011 02:16 PM
Ohhh i put the code on the radio and it worked. The nav was replaced but i dont have the new code what should i do?
KN_TL Dec 26, 2011 02:33 PM
They should have given you a new sticker. Call the dealer with the new serial number. You'll have to pull out the deck to get to the serial number sticker.
Justin0104 Oct 21, 2023 09:06 AM
So here's something unusual, i actually went to the website to get the code for my navigation, i put on the navigation serial number and it actually did bring back a 5 digit code 😅 it even says next to it "navi code". I've long since swapped out the oem head unit for an aftermarket one, but haven't been able to find the serial number for the navigation till today and then finding out somehow its a 5 digit code is concerning
© 2026 MH Sub I, LLC dba Internet Brands
