3G Acura TL - Aftermarket Amp & Sub Install - DIY Photo Guide
Old 03-20-2013, 08:48 PM
rody084's Avatar
After countless hours of reading through this incredible forum, I was able to install a new aftermarket sub into my 2006 TL with Navi. I can't begin to cite all the helpful posts, but hopefully mine will help someone in the future.
https://picasaweb.google.com/rody084/2006AcuraTLCustomUncald4EnclosureSubInstallation?a uthuser=0&authkey=Gv1sRgCPGj2ZON8-qtigE&feat=directlink
Parts:
Uncald4 Custom Enclosure (thank you, Travis!!)
Dynamat & Road Kill
Subwoofer (JL Audio 10W3v3-2)
http://www.amazon.com/JL-Audio-10W3v3-2-Single-Subwoofer/dp/B000TDCN2Q/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=320QZ2KH3QNM7&coliid=I3JDT2LAKISKKG http://www.amazon.com/JL-Audio-10W3v3-2-Single-Subwoofer/dp/B000TDCN2Q/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=320QZ2KH3QNM7&coliid=I3JDT2LAKISKKG
Amp (MRP-M500 - Alpine Monoblock 500 Watt RMS Power Amplifier)
http://www.amazon.com/MRP-M500-Alpine-Monoblock-Power-Amplifier/dp/B0013TQ6FK/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=320QZ2KH3QNM7&coliid=ICBRMYSU2W7GL http://www.amazon.com/MRP-M500-Alpine-Monoblock-Power-Amplifier/dp/B0013TQ6FK/ref=wl_it_dp_o_pC_S_nC?ie=UTF8&colid=320QZ2KH3QNM7&coliid=ICBRMYSU2W7GL
Amp Power Kit - 8AWG (one I picked up at O'Reileys since I was desperate)
Sub Grill (JL Audio SGR-10W3v3/W1v)
http://www.crutchfield.com/p_136SGR1031/JL-Audio-SGR-10W3v3-W1v2.html?tp=1053&kw=&org=pla&nw=g&crv=15802862185 http://www.crutchfield.com/p_136SGR1031/JL-Audio-SGR-10W3v3-W1v2.html?tp=1053&kw=&org=pla&nw=g&crv=15802862185
Fuse Tie-In (Bussmann BP/HHH ATM Add-A-Fuse)
http://www.amazon.com/Bussmann-BP-HHH-ATM-Add-A-Fuse/dp/B000GKEXK2/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=320QZ2KH3QNM7&coliid=I3ITFEK0AYWPIR http://www.amazon.com/Bussmann-BP-HHH-ATM-Add-A-Fuse/dp/B000GKEXK2/ref=wl_it_dp_o_pC_nS_nC?ie=UTF8&colid=320QZ2KH3QNM7&coliid=I3ITFEK0AYWPIR
Hope this is helpful to someone out there!!
Rody
The following 3 users liked this post by rody084:
kpc2593 (03-31-2013), sockr1 (01-27-2015), TL_Trell (01-24-2014)
Old 03-24-2013, 10:26 AM
RxWorld's Avatar
Awesome post man! Looks like a clean install. I am actually going to be doing the same install with my box from uncald4. I had one question though. How did you secure the box to your car? Mostly thinking along the lines of anti-theft. I was thinking of drilling holes into the car but didn't know if that was a good idea, haha...
Old 03-26-2013, 08:44 PM
rody084's Avatar
RxWorld: I'm by no means near an expert in this... but my concept of anti-theft in this case was eight (8) 1" self-tapping sheet metal screws through various locations. Just be really careful to memorize (or in my case, take a photo) of where all the lines / tubes run before you put your liner back in so you can dodge anything important... so far everything seems to still work
Good luck with your install! Let me know if you find any way to improve upon what I came up with.
Rody
Old 03-29-2013, 10:07 AM
cnwahlheim's Avatar
Your custom enclosure looks amazing! Are those still available from uncald4?
Old 03-31-2013, 11:00 PM
kpc2593's Avatar
This is awesome, def gonna tackle this with my next paycheck.
Old 04-01-2013, 12:23 AM
6th Gear
lakallo's Avatar
Thanks for the post, everything looks good.
Old 07-30-2014, 10:02 AM
VaBeachTL's Avatar
No LOC or Hi/Low converter? where did you get the connectors to go into the amp speaker input side?
Old 07-30-2014, 11:17 AM
blownby's Avatar
How do you like the box and JL sub?
I am looking into that same setup as well, just maybe a 12" and or w6
Old 07-30-2014, 12:37 PM
vietxquangstah's Avatar
use the speaker level input on the amp and wire it to the + and - wires that runs to the factory subwoofer.
They are easily accessible from the trunk. you just have to pull the carpet liner down in the trunk.
I installed my sub and amp without removing any seats or rear deck
VaBeachTL (07-30-2014)
Soul_Deamon
11-13-2018 04:44 PM
jblessing
08-08-2018 09:43 PM
james357
02-13-2016 02:37 PM
trinikidcl
09-04-2015 12:56 AM
Quick Reply: 3G Acura TL - Aftermarket Amp & Sub Install - DIY Photo Guide
