2013 Nexus 7 DIY Install in Type S with Reverse Camera
Old 08-28-2017, 01:56 PM
  #121
8th Gear
farbeyond's Avatar
Hey guys,
quick question, If i wanted to re locate my navi in to my center console, not only i have to extend the wired from it but would i have to dig in to vent system that leads to rear console? like this? I think i got this from Peter6 thread. (hope its o.k Peter)
Old 09-07-2017, 01:54 PM
  #122
4th Gear
uberNoobZA's Avatar
This is inspiring. great job !!
Please could you explain how to configure the tablet to go into deep sleep when the incoming power turns off ? I cannot seem to find this option in Power Event Manager
Old 09-07-2017, 02:21 PM
  #123
peter6's Avatar
Select FI mode and firm sleep. It works only when otg cable is connected.
uberNoobZA (09-07-2017)
Old 09-07-2017, 02:25 PM
  #124
4th Gear
uberNoobZA's Avatar
Ah right.... I don;t have my OTG cable yet :-(
Thanks for the speedy response
Old 09-08-2017, 03:54 AM
  #125
4th Gear
uberNoobZA's Avatar
Does PEM also stop the tablet from turning the screen off when there is no input for a while ? I know that I need to disable lock screen, but under display settings, I cannot disable screen off
Old 09-08-2017, 10:44 AM
  #126
guitarplayer16's Avatar
Received 2,316 Likes on 1,690 Posts
That's a stock android feature - Unlock Developer Options, in developer options menu you'll have option for "stay awake".
I have my screen-timeout set to max which is 30 min I believe so after 30 mins of no user input, the screen will remain on but be dim.
uberNoobZA (09-08-2017)
Old 09-08-2017, 11:58 AM
  #127
4th Gear
uberNoobZA's Avatar
Smile
Great. Thanks !!
Old 11-21-2017, 11:18 AM
  #128
3rd Gear
Turboteg630's Avatar
Thanks Sockr1 for this step by step guide on how to install Nexus 7 tablets in our Acura TL's. I've been dreading the black screen of death on my navigation in my 2004 Acura TL for a couple years now and finally took on this project in July. I bought everything on the list from Amazon and received within a few days at my door (thanks Amazon Prime 2-day shipping). After loading the kernel onto the Nexus 7, install took only a couple hours. Everything works great except the reverse camera.
Looks like several others are having the same issue with the latest Easycap Viewer software. I tested the back up camera and relay with a regular TV monitor and so I know this works correctly. Also tried to get the older Easycap viewer software however it doesn't look like this is available since everything defaults to the latest software version for download.
Appreciate if anyone finds the solution for the reverse camera with the newest Easycap software to post in this thread.
Old 11-25-2017, 05:56 PM
  #129
I have the latest Easycap viewer on my setup and no problems at all, so I don't think that's the problem.
I don't think it is mentioned in the DIY but Easycap itself needs to be setup properly.
What seems to be the problem for you? When you go in reverse Easycap doesn't automatically open?
Or is it that Easycap opens but there's no image/scrambled image?
If the latter, change the setting from PAL to NTSC. I think you tap while easycap is open to show the menu and then click settings on the top right.
For me it was set default as PAL. After I changed that setting I was getting an image.
Old 12-05-2017, 12:20 AM
  #130
Jodan Lovelace's Avatar
Unhappy 2005 Acura TL navigation
Hi my only question is how Does car play tablet audio if mine doesn’t come with aux for do I need an isimple kit?
Old 12-05-2017, 07:48 AM
  #131
peter6's Avatar
https://acurazine.com/forums/3g-tl-a...l-04-a-949899/
Yes, you will need iSimple or something similar.
Jodan Lovelace (12-05-2017)
Old 12-05-2017, 08:41 AM
  #132
Okay I basically want a basic tablet setup no back up camera just audio! Will I On the future be able to set up aftmarket amplifier and subwoofers? With just having tablet installed or do I need to install a aftermarket face off radio also?
Old 12-05-2017, 10:20 AM
  #133
sockr1's Avatar
Received 1,158 Likes on 909 Posts
i run a full aftermarket speaker and sub system with the tablet. no need for a faceplate/double din.
here's my setup:
https://acurazine.com/forums/3g-tl-a...nk-sub-955600/
Old 02-22-2018, 03:22 PM
  #134
6th Gear
Cardoflex's Avatar
Mirroring
Is there a way to mirror my galaxy s7 to the nexus 7
Old 02-22-2018, 03:48 PM
  #135
peter6's Avatar
It's like 2nd link from google:
https://airmore.com/mirror-android-to-android.html
Try searching "android to android mirroring"
Old 02-22-2018, 03:59 PM
  #136
6th Gear
Cardoflex's Avatar
Iol i think i should ve been more specific I want to mirror without using wifi
Old 02-22-2018, 04:36 PM
  #137
Received 8,575 Likes on 6,626 Posts
LMGTFY
Old 03-08-2018, 02:56 AM
  #138
hamburglar490's Avatar
Trying to do this now, but noticed the EasyCap linked to in the tutorial is sold out. Is it fine to just buy any EasyCap off eBay that looks similar?
Old 03-08-2018, 09:37 AM
  #139
Welcome to the 3G world brother!
I'd find an easycap with the exact same description as the one linked.
Old 03-08-2018, 11:41 AM
  #140
Haha thanks man, small world! Picked up a 08 TL-S in CBP this weekend, looking forward to making some changes. And alright awesome, I'll pick one and hope for the best. Will post back here if whatever one I buy works or not to save people the trouble.
Old 03-08-2018, 01:20 PM
  #141
sockr1's Avatar
i've heard from a few people that the link doesn't work. someone sent me this link and said it worked for them for the easycap, give this a try!
Amazon Amazon
item named "Easyday EasyCap DC60 - USB 2.0 Video Capture Adapter with ChipSet UTV 007 and Video Editing Software" by Easyday
Old 03-08-2018, 03:52 PM
  #142
https://www.amazon.com/dp/B0126O0RDC...v_ov_lig_dp_it
Oh okay great, just ordered it. Thanks!
Old 03-14-2018, 12:24 PM
  #143
Csakstar's Avatar
Install
Anybody near Chicago that would be willing to do the install for me? I've had the parts for over a year but have been unable to find anyone to do it for me.
Old 05-09-2018, 08:59 PM
  #144
Clifbarz's Avatar
relay position
Where exactly is the relay after installation? under the center console or in the trunk?
Thanks!!
Old 05-09-2018, 10:39 PM
  #145
sockr1's Avatar
Thanks!!
i believe i put mine in the center console. you're tapping into the usb cable right after the usb hub, which is in the center console so that seems easiest
Old 05-09-2018, 10:44 PM
  #146
i shoved everything under the cup holder - DAC, all usb cables, relay, easycap
one usb extension wire is run into the center console storage which is used with my USB for music
Old 05-10-2018, 12:16 PM
  #147
UA7X's Avatar
It really comes down to personal preference and convenience. I put my relay in the trunk with the easy cap and the backup camera. I had a really long Usb3.0 extension cable, so I cut up and installed the relay on the short USB that the easy cap came with and the ran the long extension to the center console with the USB hub.
I feel I get better video signal and quality this way vs running the Yellow RCA cable (which came with my backup camera). But this could just be my imagination lol.
JMiles_T (05-26-2018)
Old 05-10-2018, 10:20 PM
  #148
Clifbarz's Avatar
Timur availability
Thanks for the quick replies!!
Is Timur’s kernel only available through that Reddit link? Just wondering because that reddit page seems hard to navigate and I don’t wanna download the wrong thing. Lol
Thanks!!
Old 05-10-2018, 10:42 PM
  #149
This is where you download it: https://androidfilehost.com/?fid=673956719939830775
You can follow these instructions to set it up, or follow the DIY: https://www.reddit.com/r/timurskerne...r_android_601/
Old 05-11-2018, 05:02 PM
  #150
Clifbarz's Avatar
Thanks for the link!
Has anyone successfully figured out how to integrate the steering wheel controls? I saw that someone used an isimple. I know of the Joycon too but I don't know if its compatible.
Thanks!!
Old 05-14-2018, 12:39 AM
  #151
Just wanted to say thanks for this tutorial, helped a ton! Getting that tablet to fit right was definitely the most tedious part, but the final product is well worth it.
Old 05-14-2018, 09:33 AM
  #152
sockr1's Avatar
^^ good job! and you're welcome! let me know if you want me to tweak the home screen for you so it's more "complete" with icons and titles.
Old 05-14-2018, 12:46 PM
  #153
4th Gear
Duppa43's Avatar
great job with the install and especially the instructions..... this may be my next mod..... THANKS!
Old 05-14-2018, 09:33 PM
  #154
Clifbarz's Avatar
Do you have to remove your back seat to run the video wire (for the backup camera) to the easycap int he center console??
Old 05-17-2018, 10:18 PM
  #155
Clifbarz's Avatar
I cant get the Timur zip files to copy over to the nexus 7 in TWRP mode. anyone have this issue?
Old 05-17-2018, 10:35 PM
  #156
Clifbarz's Avatar
nm, i got it to work
Old 05-20-2018, 09:25 PM
  #157
So long shot here guys, but today my nexus isn't turning on. Checked all wires, it's still getting power, but seems to just be stuck asleep. Anyway of getting it back on without ripping all this stuff out again?
Old 05-21-2018, 09:02 AM
  #158
peter6's Avatar
Do you have access to the power button? If so just hold it until something happens.
Try double tapping on the screen, cycling power couple times, etc. Otherwise get to the power button.
Old 05-21-2018, 11:56 AM
  #159
JMiles_T's Avatar
I did. You don't have to unbolt everything all the way though, just unfasten one side of the back cusion to make enough room to pass the wire along. You will need to pull the bench though.
The bench is held by one bolt along the back wall, and two clips where the cusion meets the carpet.
Old 05-21-2018, 12:30 PM
  #160
JMiles_T's Avatar
My solution to Nexus battery drains...
TL; DR version:
My solution was to install a relay on the USB cable between the Nexus 7 and the hub, specifically the red 5 volt power wire. The relay is powered whenever the vehicle power is switched on, and immediately cuts the connection when the key is switched off. The relay is tucked under the center vents, right above the tablet, so it's easy to reach if I ever need to replace it with a new one.
The backstory:
I've often started my car to find the Nexus battery power level diminished substantially compared to what Timur promised. No matter what apps I terminated or disabled, it kept happening from time to time.
I've determined that even during sleep mode, my Nexus 7 still sends some power through its USB port.
The power drain was barely noticable when I had only my FiiO audio converter plugged into my USB hub, but when I combined that with my Easycap and my GPS reciever the situation became exacerbated to the point where the Nexus battery was totally drained on several occasions.
I confirmed this by unplugging my USB hub and letting the tablet sleep overnight.
The following day, the power was still 100%.
Quick Reply: 2013 Nexus 7 DIY Install in Type S with Reverse Camera
