2007 Acura TL wiring diagram
Any symptoms were can maybe help you with diagnosing in the meantime
Not at the moment thanks. Did have several symptoms last night. Wife drove car home. Started to through odd lights on the dash, check battery, check gas cap. As she got home, car started lurching (as she put it). Coasted into garage. I check car, all electronics dead. Check battery voltage, .01v!? Try to jump start it and jumper cables got so hot burned my hand. Changed battery(very dead). Attempted to connect cables, positive fine, negative huge spark the first time, non the second attempt. Car still dead. Remembered having to attempt reset with key in door before once. Tried key in door, turn once right, center, then left. Repeated 2 times and all of a sudden door locks actuated, headlights flashed. Opened door insert key car starts and all is fine. Something caused a complete dead ground for a time then reset or changes states. Only thing I can think of is the theft deterrent actuator/switch/relay stuck or grounded. 2007 TL, near perfect, 62,000 miles. Thought was to trace system and check components. Do not trust it to drive at the moment. Advice? (sorry for the long winded reply)
Forum Contributor
Received 1,391 Likes
2007-2008 Acura TL Electrical Troubleshooting Manual
http://techinfo.honda.com/rjanisis/c...untry=1&lang=0
Skirmich
1/2G MDX (2001-2013)
10-10-2016 05:45 PM
brgubs
10-10-2016 12:19 PM
donchicago48
10-09-2016 09:25 PM
