10 in free air subwoofer in rear deck ??
lookin to change my stock 8in free air sub ..wanted to know if anyone tryed to put a 10in free sub in the deck ...i know i would have to cutt the deck to make room for the 10in sub ..can it be done?? has anyone tried ??i searched but didnt find anything....thanks
I swapped my free air sum in my 08 accord i had with a Kicker C8 8in free air sub. It sounded great on the 100rms amp.
6spd FTW
Should be no problem to support it. Just remember that you are modifying / removing some of the structural rigidity of your vehicle (albeit not much). If you decide to do it, you will probably want to seal the top of the deck with some sound deadening material. Also, you will likely have to cut the bottom of the rear deck as well. Most 10" subs will be too deep to just fit in without additional cutting on the bottom.
You might as well do a 12 or 15 free air behind the rear seat. To do even a 10" in the deck correctly you need to seal the trunk from the rear. Its less work and cutting to build a baffle behind the seat. I have a single 12" in this configuration and it sounds great and takes up very little trunk space.
rockyboy
08-04-2024 10:35 AM
3GTLOwns
09-09-2015 09:51 PM
