07' TL stock subwoofer ?
Be kind to us truckers !
Has anyone's stock subwoofer taken a s#@*! ..since theyv'e had theye'r car? ...mine sound's like DoDo at times! and seem's to distort easily with out barely pushing it !...or it just me and I'm just hearing thing's?...are there any replacements on the market with a direct fit in the stock location?
We have a ton of sound deadening material thru out our cars, so a drop in replacement or even the Basslink will not be much of an improvement. My suggestion is to go with one powered 12" sub in an inclosed box. That way if you listen to music from mild to wild, it will be tight and responsive vs boomy. Bear in mind that the type s uses the active noise canceling, so you'll have to disconnect the mics to prevent system hum. The install is really a cinch if you have any 12volt experience.
kb1rl
09-30-2015 10:17 AM
