'06 TL Navi error
Drive may have died.
Suggestion - post your question on the 3G TL forum to get more replies: https://acurazine.com/forums/forumdisplay.php?f=94
Received 2,329 Likes
Look for loose wire connections in the trunk unit.
Registered but harmless
Received 1,149 Likes
If it has grooves or gouges in it, the drive is bad per the TSB on the Navi drive.
If the DVD looks fine, clean it and reinsert to see if that solves your problem.
:ibthreadmoveto3GTL:
It does tell you the disc is out. It also will display other if pci door slot is open ect.... One thing I noticed, when I had the unit in my hand - the cooling fan was not operating when I installed the disc.
Pat Catullo (09-01-2011)
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
phillyguerrilla
09-26-2015 11:27 AM
