'06 to '07 TL HFL swap need a wiring diagram
Hey guys, so I have an 06 TL non navi, basically the hfl unit was stuck on booting up mode. I performed all the reset methods mentioned. Anyways I got one from a junk yard from an 07 TL non navi. And found the connectors are different. I have all wires ready to be spliced but I can't seem to find an 07 hfl wire diagram. If anybody can point me in the right direction that'd be great, I usually figure stuff out on my own with some research but I've already blown one radio fuse so I wanted to reach out for some help. Or would it be a better option to buy an aftermarket one since this one may be shot as well with the known 5 year life span of these boxes especially here in the Texas heat destroying everything. Thank you all in advance.
jojo32m (08-17-2022)
hello . was wondering if you had the pin diagram for a 2008 rdx tech pack. going to use the 12v power source in the center console. hopefully dont drill a hole in the navi lol. guess i could check n see if the pin out matches mine n try but reather not burn it up if i can. ty in advance.
jojo32m (08-23-2022)
hondeducation
10-19-2014 10:06 AM
jevans06
03-07-2014 04:08 PM
