'04 TL rear subwoofer replacement
Hello everyone,
All of the sudden my rear subwoofer started to make some weird crippy noise and i realized it's time to replace it. However, I could find any subwoofers that would look like mine. Any suggestion where I'm supposed to look for a new sub at? The sub is the middle speaker in the rear dash.
Okay I'm looking to put Sony amp 1000W and a sub-box into my trunk with (1400 W) woofer. Now I have a question, can I connect it to my regular audio unit or its gonna be a problem? I don't wanna touch my NAVI ..
Cut the wires going to the factory sub when you remove it and connect them to a line out converter or if you amp has line level inputs just extend the wire and put it to the amp. I can control my sub amp with the stock nav head unit. It was actually easier than I thought it was going to be, just installed my stuff last weekend.
Kicker makes an 8" 2 ohm free air sub that is dirt cheap, like $50 or so but I doubt it'll sound any better than stock as it gets very low power and is in a bad location. And free air sucks.
Free air is awesome.
I upgraded my 08 Accords speaker with Audio control processor, Memphis M-class 2-way speakers and front components, as well as a kicker free-air sub. One thing to keep in mind. If you wont DEEP bass from a sub, it wont happen with a free air sub. I only powered the sub with a 100 watt amp. Any more power than that and the sub would bottom out. If you listen to music that with mostly mid-bass like R&B, Club music like techno/trance/break beat, and light hip-hop, It'll be fine. If you won't smooth deep bass then a false floor or side firing set-up will be a more prolific set-up. But at this point in my life, i'll be only upgrading the full-range drivers for 2-way cleaner drivers and im done. I trade my cars too fast (every 2-3 years) that its not a good value for ME to over do my audio upgrades. Keep us updated on what you do. Oh btw. When I swapped out the speakers/sub I put dynamat at every location.
So basically I can swap the stock amp with my aftermarket which is sony X 1000W and replace the sub with 1400 W and it will 100 % risk free. I mean i don't wanna burn my navi unit.. or amp itself cuz its kinda pricey
Should be risk free other than Sony subs being junk.
Free air/IB will get lower with less power than sealed. It will usually have a flatter frequency response extending lower but just as high as sealed. You have to have the displacement to get low though.
Well yeah that sony X amp is 4 channel compatible. I thought it's gonna be a direct replacement. So basically I would need to take a signal from factory amp plug it in to my Sony X amp and than hook it up to the subwoofer?
Look dead center on the fire wall, maybe in inch or so lower than the strut bar. There's a black grommet there, I pushed it in with a screw driver, fed in my wire and it poked out by the pedals inside. I took off all the plastics in the engine bay so I had an unobstructed view, there's pics of it somewhere on here if you go through the stickies on amp installs.
mada51589
Jan 9, 2025 04:40 PM
AndrewS
19
Mar 14, 2024 06:59 PM
