Zaino and Clear Bra
Zaino and Clear Bra
I don’t know if I should Zaino then install clear bra or clear bra and then Zaino. Im using the 3M clear bra product. Any info you could give would be great.
When I had mine done, I did the zaino first. They clean the car with alcohol when they install the clearbra so they effectively remove the zaino. After they apply the clearbra, you have to reapply the zaino.
Reapply over the clear bra.
Clear bra then Zaino
When they put on the clear bra, the installer have to strip off (wash off) all waxes on areas where the clear bra will be installed. So to save you some trouble, just Zaino after clear bra and you can apply the Zaino on the car as well. I have my Z with clear and Zaino for 1.5 years already, and still looking good and loving it....
Zaino under fingernails
bigbooboo,
I would use Dawn to wash the car, then Claybar the area where the Clearbra will go on, then drive slowly to the vendor to get it installed. They'll also strip down the paint before applying the product, but you'll ensure that a good job is done.
Good luck!
Good luck!
