Winkles on Inside Door Panel By window
Purchased Moleskin from Flynx and installed it myself. Order comes with good detailed directions on how to do the install. 2 ways you can do it, 1 completely take off the door panel (recommended), 2 Remove a few things and Carefully Pry away the door panel enough to install Moleskin. I couldn't get the screws off of the front door panels on the bottom where the rubber thing is on it. When I unscrew it, its keeps on spinning and doesn't want to come off. Since i couldn't get the screws off, I did Option 2. (The directions he gives you Does Warn you ahead of time about the wrinkles, some ppl get them, some ppl dont) Unfortunetly I did. Does anyone else have the wrinkles on there door panel? If so, what can i do to get rid of the wrinkles?
Thanks in advance for any feedback
SidhuSaaB
05-30-2020 12:40 AM
