Windshield Sunscreen
Originally Posted by xristos
If you do a search, you will find a member on this forum w/ a sunscreen for the front & rear.
A URL would be even better.
.:HALCÓN DE LA NOCHE:.
Originally Posted by Ron A
Can we have a hint.
http://www.acura-tl.com/forums/showt...light=sunshade
This thread refers to the sunshade group buy:
More sunshade info:
Hope that helps.
xristos: Points to you. When I read "sunscreen", my mind came up with an absolute blank. All I could think of was what is the PF factor? Aha, it's "sunshade".
Thanks for the help.
Everything u need for the beach!
They look like great sunshades. I wouldn't need their use because I work at nights & garage my car during the day.
Thanks, Ron A !
The best fitting sunshade you can buy will be the HeatShield sunshades. I had one for my G35 and now I have one for my TL. They are computer designed to fit your windshield perfectly. I highly recommend them. You can order them direct from CanvasWorks website here http://www.canvasworks.com/. They are not cheap if I remember correctly, something like $40!!!
Forever Young
The best is www.dashdesigns.com, built in Tempe, AZ! It is priced right and is retractable. There is no seam in the middle. I recommend that you remove the "A" pillar covers and drill the two holes to hold the right side retractor and the same for the left clip. Install a nut or clip that will give the screw a positive connection. You can use the 3-M adhesive that comes with it, however the screw is more positive. I have had mine for 2 1/2 years on the Honda and love it. Wont damage air bag if you remove cover to do install. Way faster and easier to use day to day.
Hope that helps, Stuart
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
