Will 2008 Acura TL Power Side Mirrors fit on a 2004 TL?
hey everyone,
I wanted to know if i would be able to replace the power side mirrors on my 2004 Acura TL with the ones from a 2008 TL? I really like the look of having the side light embedded in the power mirror housing. The glass on both my exterior power mirrors has that funky brown staining on it (i am assuming it's from water getting into the space between the mirror and backing or something like that) and i want to replace them with new ones. the only issue is i would have to get them painted to the 2004 Blue Pearl color, but that's something i can tackle if i have to.
They should be a direct replacement. You will have to tap the lights into the turn signals.
That brown staining is from leaving the mirror heaters turned on. It would be much cheaper and easier to just replace the mirror glass, if you didn't want the signals.
swedrows (03-26-2012)
thanks for the quik reply guys! yeah i can also just replace the glass itself, but the "replacement" glass i found online that is heated, blue replacement glass costs as almost as much as buying a new side mirror. i like the look of the blue glass so i'd like to stick with that at least to keep the car looking oem
Head a da Family
the overexplainer
is it? I didnt have any problems pulling my pass side mirror off to throw some lube inside so it didnt creak (plastic on plastic creaking due to flex, not the reverse clicking problem). Pull door panel off, pull plastic cover over bolts and undo the 3 nuts.
Jokerman
I did it. You have to swap the mounting bolts from the old mirror to the new one. The 2008 mirror bolts are larger than the 2004 bolts. When I tried swapping out the mirrors, they wouldnt go in the holes correctly until I swapped the bolts. Wiring isnt too bad, I believe there is a DIY in the 3g garage.
Where to Buy Side Mirrors with Turn Signals for a 2004 Acura TL
Hi Everyone
i was just wondering if someone can point me into the right direction
im looking to buy the Side mirrors with turn signals for my 2004 Acura TL. in other words, i want to install the Side Mirrors that came on the 2007-2008 version of the TL. but i cant find them anywhere. i've searched Ebay and other auto parts places on Google but still came up empty handed. if anyone could tell me where i can get these side mirrors from, that would be great. thanks so much in advance
173rd Airborne!
Hi Everyone
AcuraPartsNow (10-04-2012)
Quick question...
By adding 07-08 side mirrors w/the integrated blinkers and wiring them to the turn signals, would this cause any "hyper blinking" problems down the road?
I only ask, because I am researching a DIY wiring for blinkers to the side markers and found hyper blinking to be an issue down the road. I don't know much about electrical loads and wouldn't know if the added wiring for lights in the side mirrors posses similar issues with the side markers.
Thanks!
Thanks!
Hi Everyone
Quick question...
Thanks!
Thanks!
jsp62 (05-22-2014)
mike from annapolis
05-07-2017 08:21 PM
nanos
11-12-2015 08:41 PM
