Why are my mpg's so low
#41
'06 WDP TL 6MT
^ Don't misinterpret the MPH thing from the previous post to mean "The faster you drive, the better MPG you will get". Yes, if you can maintain a high speed cruise that will be ideal. But racing from light to light as fast as possible will give you worse fuel economy.
#42
Quote:
Originally Posted by MillerTime12oz
Check your air filter and spark plugs. I put on mostly city miles and I average 21. Like they said it could be your driving habits. Do you go straight from gas to break, take off quick, drive short distances??? Short distances in cold weather will cause for low miles too. I get better milage in the summer months.
clogged air filter will not cause loss of mpg.
#43
Dumbass. LoL. I didn't know 24yrs old still said that.
I don't trust ONE person with ONE result. I prefer see multiple tests. Fill up at the same pump with the exact same volume of fuel. Drive the same exact mileage, over a period of say a month. Preferably in the same weather conditions. I'd say 4 weeks with 4 fill ups is an adequate test.
How much are you idling during a course of a tank of fuel?
Tire inflation has a huge impact on fuel economy.
https://acurazine.com/forums/showthr...costaracer+mph
#45
The low mph aso means hes sitting at a stop a lot or sitting in his car with the engine running. The fuel calculator is still working when you're just sitting with the engine running. Keep that in mind folks.
#47
This myth originated on carbureted engines and it was real on those engines. A restrictive air filter was the same thing as having the choke partially on. It resulted in a richer mixture and less mpg. On a fuel injected car, AF stays the same no matter what and the only thing you can lose is power from restriction.
#48
My MID is very accurate. Last time I checked it read 18 MPG and the calculation at the pump was 18.4.
It has to be a more sophisticated system than just giving an average MPG based only on the average MPH otherwise we would all be getting the same MPG at an average of 19 MPH. I've heard of some people getting as low as 13 MPG at that when I usually get about 20-22 MPG.
Myy MID is also very accurate at the pump, 24-26MPG, mix of 65% HWY, 35% city. Pure HWY I am usually around 28-31MPG. Reset w/ each fill-up. I also do a hand calc, based on Gallons put in and total miles on prev. tank. They are remarkably similar, always within 1mile of each other.
#49
'06 WDP TL 6MT
Cool, keep us updated. If you reset it at every fill up, you can gauge how your driving style effects your mileage. If you see you're getting 13mpg for the first half a tank, it might prompt you to lighten up your foot for the other half.
#52
It's your driving style. You must be having fun with your car and/or do a lot of city driving.
I got bored this week and wanted to see how high I can get my average MPG so all week commuting to work, I tried staying between 55-65mph and ended up at 30MPG. Normal driving I'm at 23-24MPG. If I play a lot, it's around 18-19MPG. I have about a 70 mile round trip commute daily.
Not sure where you see two MPG. Are you sure one isn't MPH?
#54
#57
Strike TWO
I reset mines after each full up
i'd say yes, i normally get >385
#58
I get around 17 mpg atm. Im not thrilled since my STI was getting about 15-16 mpg, maybe its because I drive 9 miles to work 1/2 in city, other half on freeway that has hills at times. I do get good MPG when i take long road trips though...
#59
I hate to tell you this but you're not getting 35 mpg. Thats way higher than this car is rated. But mine used to say that too, but then it mysteriously changed to something much lower. The best way to tell is check how many real miles on the odometer you get per fill up. The old fashion way.
#61
and coasting.. haha
#62
#63
Have you actually checked it manually? Like with a calculator and reading the gallons on the receipt... You can't trust the dummy thing.. Because nobody gets more gas mileage than what the car is rated unless you lightened up your car.. but even then I would be surprized to see more than what it is rated. Manufacturers always rate at maximum mpg. And they rate their cars at optimum conditions and perfect tire pressure and all that.. Probably on a nearly empty tank too.. And since they rate at maxium MPG, and its a lot lower than your "33-34", then thats proof that your gauge is messed up because "AVG MPG" is always LOWER than just "MPG".. which is maximum.
3 ratings:
http://www.cars.com/acura/tl/2008/specs/
http://www.fueleconomy.gov/feg/bymake/Acura2008.shtml
http://autos.yahoo.com/2008_acura_tl_type_s_5_spd_at/
So with all that in mind, you can believe what you want to believe.. but my question is, why are these 6 cylinders rated at 19 in the city when a corvette is rate pretty clsoe.. like 16.. And thats 400+ horsepower. Sounds like Acura needs to step up. I assume that is optimum also for a vette and no heavy acceleration.. The hwy mileage is about the same.. http://www.fueleconomy.gov/feg/bymod...Corvette.shtml
3 ratings:
#64
mpg is one of those things you shouldnt be worry about in a TL man. for how nice and powerful it is, getting 18-36 mpg city/highway is pretty damn good. Thats what i have all the time, just 20 ish. I live about 305 miles from vegas and I actually did make ONE WHOLE TANK all the way up to vegas. pretty sweet huh ? all freeway at 70-80 mph.
#65
3 ratings:
3 ratings:
#66
I've used the TL for food delivery in the past 2 years netting over 50k miles (don't ask, it's either the TL or the ES) which means all city driving. Lead foot give likes 12-14 mpg and normal driving gives up to 15-17. To get anything past 17 mpg on pure local mean I have to roll up to every stop light, grandma style the pedal and drive 15 mph between stop signs. Highway is like 31 mpg @ 65-70mph.
I've noticed local to some people means the speed limit is 30mph and for other the speed limit for local is 45mph so everyones local mpg will be different depending on where they live; rural or urban.
#67
Cold weather makes the car work harder. No matter how you drive, the mpg is going to go down in the winter time. I get 23-24mpg avgs now compared to the 27mpg avgs in the spring and fall.
#68
You can do the sea foam and plugs wires thats good but that will not make a change, the air filter will if its really bad. I drive for work and have over 500k miles with several different cars. I have always checked my MPG's just to keep tabs on the car. Things i have noticed that make a difference in the MPG's. The biggest one is how you take off from a dead stop, such as stop signs and stop lights. If you give it hell and give it full throttle at a stop that seemed to make the biggest diiference. Barely pushing on the gas and slowly rolling to your desired speed, yes you will not have fun and look old but what do you want MPG's or fun. It cost money to have fun. All the numbers that everyone has provided are accurate and the MID about the cars Average Miles Per Gallon is dead on + or - 1. I ve used 87 and 93 and the mpg's seem to be about the same. Once you have had the car for a while the mpg;s will get better. Or once you get a few speeding tickets. 15-21 around town 30mpg on the highway. Keep in mind If you let your car warm up like I do in the winter for 15-20 minutes that will contribut to the lower around town mpgs. If you you dont have a copld air intake that will help for a few.
#69
Patiently waiting....
I would suggest, when you reset it,do it when your on the highway so you start off with a good number then you work your way down due to the city stop and go much easier to keep the mileage higher.
Its like in school when you start off with an "A"(good mpg). As you do your thang correctly you can keep the "A" then if you started off with the "F" and tried to work your way up to the "A", but if you reset right after you get out of the gastation you already start with the "F" due to the city stop and go which already kills the mileage.
