WHITE license plate lights
Anybody have pure white license plate lights? I've tried several led lights that say they're white but they all have a hint of blue in them. I've seen some on the road with pure white light. Anyone know where to buy them? Thanks!
1 Post
If you want to do it right...https://acurazine.com/forums/3g-tl-2004-2008-93/white-cold-cathode-license-plate-how-3g-garage-g-070-a-605201/.
No plug and play bulb is going to look as good as this. good luck
I'm afraid because of the climate up here, CCFLs aren't ideal, though =(
Might have to stick to getting good LEDS.
'06 WDP TL 6MT
I know you only need one, but then if the inverter (or whatever its called in this case) goes out, I wont have a spare. Or maybe I'll use the other set to light the interior of the trunk.
I agree on the CCFL's. I used the 4" kit. Two 4" tubes and a bit of plexiglass. Only problem I've seen is the dirt and grime building up on the inside of the lense. If I ever get in there again, I'll fabricate some kind of cover on the top to divert any water away from the lights. As far as cold weather, I probably wouldn't know since it doesn't get too cold here. Plus, I don't normally stand behind the car when I turn the lights on. But I've never seen either of the lights not working and it's been about a year and a half.
I'm so sold on the CCFL's, I started working them into other projects, too. You should see the boat all lit up at night!
try this.
https://acurazine.com/forums/3g-tl-2004-2008-93/definitive-led-thread-all-youll-ever-need-know-about-leds-3g-garage-g-076-a-633045/
I know im noob material but this is the first mod i ever did to my car and this thread helped me. its got everything in it. But it sucks cuz its over 12 pages or something now...
Hope this helps.
Hope this helps.
Silvermoon_Knight
10-22-2015 06:25 PM
darksky
09-05-2015 03:11 AM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
