Where is 'Under Dash Fuse/Relay Box'???!!!
Just installed new Ignition Coil and NGK plugs.
Need to reset the ECU by pulling the 'clock fuse'. Looked at the Service Manual pages 4-16 & 22-61...
How the @%# do you get to the 'Under Dash Fuse/Relay Box'? Is it in the driving compartment? I pulled the
And which fuse is the "Clock Fuse"? I looked on page 22-66 & 22-68 and couldn't figure it out.
Help! Trying to finish this simple job without too much headache!!
BANNED
well the fuse box is under the steering column, near the hood latch.
BUT if you're just trying to reset your ECU...just take the negative terminal off your battery for a few minutes and reattach it. 10mm socket.
BANNED
it will clear the codes but they will still be stored in the system. do you have navigation on your 04?
SpinuidS (04-12-2012)
No Nav. Found the Fuse Box. Duh.
Disconnected battery and pulled ignition coil relay....no more orange triangle of death. Ride running smoooooooth with the new coil.
Thanks!!
Thanks!!
AZ Community Team
Received 7,770 Likes
Two Words: Owners Manual.
J-020: 3G TL Owners Manual & Navi Manual Links
https://acurazine.com/forums/3g-tl-2004-2008-93/j-020-3g-acura-tl-owners-manual-navi-manual-warranty-booklet-pdfs-851625/
( ^^ in case you didn't get yours)
Acura604
20
08-05-2017 12:55 AM
