What Tires to put on OEM 18's
I just wanted some of your comments on what you feel is the best tire to wrap the OEM 18 Acura rims with. Please keep in mind that price is a big issue. I want to start to research a few tires. Please help me out. Also please let me know what size to get. Thanks!
The Yokohama AVS ES 100 is widely considered to be the best value in a high performance summer tire, and is OEM Spec for the 18s from Acura. I will be putting them on the 18s in the Spring, and put about 27k miles (including HPDEs) on the set on my BMW.
I believe the 18s are 235/40/18, but they may be 245/40/18. You just want to keep the same overall diameter of the stock tires, so as the rim gets larger the sidewall gets smaller. Whatever www.tirerack.com recommends should be fine.
cammy5
09-04-2015 11:26 PM
