What is leather and what is vinyl in the car?
Does anyone know *exactly* what is vinyl and which ones are leather in the car?
Trying to figure out where to apply leather condition vs vinyl cleaner/etc....
thanks, pps
thanks, pps
Re: What is leather and what is vinyl in the car?
thanks, pps
thanks, pps
What would happen to the vinyl if you apply leather cleaner/conditioner? It won't damage it, will it? It's been a while since I used any kind of leather care stuff. TIA.
Only the parts of the seat where your body touches. The top most surface. The sides and back are vinyl. If you look closely, the grain pattern is different on the vinyl.
Just use 303 or ? on the vinyl parts.
I don't know if Leather cleaner/cond. would damage it, but why try?
What about other areas?
What about the back seats?
What about the arm rests?
What about the performated stuff on the side of the doors?
Steering wheel?
on a 6sp the stick handle, and stick case?
thanks, pps
Steering wheel?
thanks, pps
Re: What about other areas?
From my comparison with a MDX, leatherette is on the doors, the back seats, the part where your butt and back touches. The parts that are leather are the seat bolsters, steering wheel and shift knob.
Steering wheel?
thanks, pps
Steering wheel?
thanks, pps
From Honda Canada (sourced from http://www.canadianautoreview.com/2004_acura_tl.htm):
Other than the obvious like seats, steering wheel and shift knob, the following apparently uses leather:
* Front centre armrest
* Centre Console
* Rear armrest
Seats are leather-'trimmed', so I would imagine anything not touching your body is leatherette.
HTH
* Centre Console
* Rear armrest
HTH
Your right! I guess Leather can be short of Leatherette.
Originally posted by GreatWhiteNorth
Marketing types won't miss an opportunity to say something is leather. In other words, if it isn't explicitly stated as being real leather, it ain't.
Originally posted by dulnev
My understanding is that there's not a piece of vinyl in this car. It's all real leather.
Overlord - Team Abyss
My dealer informed everything in the car was leather, except the rear of the seat. Whether or not this is the case, I cannot say. However, I can't tell the difference so i don't care, personally.
It is actually pretty obvious by just touching the areas. Leather feels smooth and the vinyl feels slightly tacky. Front seat cushion sides inboard are vinyl, ouitboard are leather. Center of rear seat is vinyl. Most of the front headrests are leather while the rear ones are vinyl. I'm not sure abought the perforated door panel areas.
more info
I called up Acura care and got the following answer...somewhat convoluded:
- seating surfaces and top side of bolster
- steering wheel, shift knob
- door panelling
BUT door armrest is leatherette
back seats --- don't know
Not convinced I yet got the right answer!
- door panelling
Originally posted by huskerfan
Acura web site says Leather trimmed seats and door panels and steering wheel and shifter. I always been told that Leather trimmed seats means only the seating surfaces and not the backs and the sides.
The word "trimmed" has absolutelly no bearing on the issue. "Trimmed" means "wrapped" in this case.
As I said earlier, if you go to the Acura web site and take the TL tour, when you choose seating it will tell you leather seating surfaces.
