what do u think of this product from redline
well its called water wetter by Red Line and it suppose to improve cooling by 30%
did anyone every use it is it smart or bad thing. Personly i really think it would do good for the TL if it really works
http://www.redlineoil.com/products_c...coolantFlash=1
it is a great product for race cars and others not running actual glycol-coolant in the system
For the TL there is no real need or improvement-
Spend the 6 bucks on a can of seafoam for the intake mainfold instead!
beinmy: I used to race and was a Redline user and Distributor back in the day when they first started
I know foam works from personal experience- blame fsttyms1 for getting me addicted to the stuff!!
Recently I did research on other forums and types of engines its being used in, and in some cases required- like performance boat motors! Added that info to recent wiki search on how the EGR really works, other info on tight tolerance engines and carbon/combustion crud buildup, and I can really appreciate the stuff now and its many uses~
Off to do my engine crankcase-oil system cleaning this weekend and change the oil.
Might even try running around on it for a day as a test, K&N filter to the rescue.
Or maybe I will just take off for Yosemite and abuse my brakes...
Or should I pull the manifold and inspect the egr ports for fun
Or should I .............
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
09-25-2015 06:14 PM
