What brand oil filter are you using?
#42
Not ALL of the OE filters are Fram/Honeywell. As you noted, the S2000 is the exception. It is now made by Filtech in the US, but uses the original Toyo Roki design. It fits the TL fine but has slightly more volume than the original 15400-PLM-A01.
Also, the original TL filter was made by Filtech (part number is 15400-PLM-A01). If you can find one (not the ebay replacement version) it is a MUCH better build quality than the Fram/Honeywell replacment 15400-PLM-A02.
Search. There is a thread where the S2000 (Toyo Roki and Filtech) and the PLM-A01 and PLM A02 are cut open and compared.
#44
AZ Community Team
Received 7,770 Likes
thanks, now i know. But i thought the A01 filters were discontinued in late2005 right??? i dont remember exactly. its been a long time, i remeber i was still working at the dealer when they did the switch.i belive a bit after that they also switched the coolant to the blue type 2. again, i dont remeber 100% exactly the dates. it was a good 4 years ago.......
Funny thing they still show in the parts lists at the parts depot stores:
Item 10 from Acura Carland, Duluth, GA.
http://www.acuraautomotiveparts.org/...s=&view=normal
#45
I didnt tell people to buy fram filters,i was trying to tell people OEM filter might also be made by fram.and if you havent noticed, most filters out there are made with PAPER!!!.I used to work at a honda dealer and one of the techs there cut open 3 filters one time. A fram,oem honda, and a K&N.And guess what. all 3 of them had paper filters in them.If you get a chance, you should cut one open and take a look to compare.
#48
Unregistered User
I'm still at 50% since I bought my car. Thinking of biting the bullet and going with Pure Power:
http://www.gopurepower.com/store/ite...=8400&dia=true
Anyone had experience with this? Or, anyone that has heard of this, have you heard anything negative?
#49
What what it's worth: http://minimopar.knizefamily.net/oilfilters/index.html
I've used the S2000 filter for my first change, and the Mobile-1 M110 for my 2nd and will continue using it despite it's $10 price tag.
#50
The Kinetics of Bleu
Anyway I use either Mobil 1 or K&N
#53
Man of God.....
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
![](http://www.amsoil.com/products/oil_airfilters/EAO_ExplodedFilter_900px.jpg)
I think , You get what you pay for
PS: The AMSOIL air filter is tops in that class also!!
#54
Received 2,599 Likes
Mobil 1 Extended Performance Oil Filters contain synthetic fibers instead of the typical cellulose filter media. With a 99.2 percent efficiency rating (under SAE J1858 Multi-Pass Efficiency Test)
Point is they all say use the standard (MID) factory change schedule under "severe" conditions. Of course they never get around to defining exactly what "severe" means.
So the question becomes are you better off running a $19 filter for 25,000 miles or putting in a fresh $9 one every 8,000 miles
#56
WIX or NAPA Gold, I buy them by the case for all my Honda's & Acura's. Just as good as Fram, OEM & some other overrated filters. Cut them apart and look, then you be the Judge.
#58
Unregistered Member
i JUST bought fram's oil filter, the guy working told me it was good it was like 14 bucks,but i think iam regreting my decision. Is there anything i should be worried about i think it is called fram tough guard?
#59
Its made of cardboard. I forgot where the picture of the cutout of the fram is its crap. Only filters I use are Wix Gold, Mobile 1, or Amsoil. Usually amsoil since my buddy knows a dealer.
#62
NOW, everyone.. I've been using it.. didn't think there is a huge difference.. What is the consensus? the OEM filter? Gonna have to stock up. I'm going to need to change the oil soon anyway.
Thats why I can't get enuff of this forum! Full of useful info!!
What's the best filter/ oil combo???? Better weather is coming so I can do all the work myself!
thanks!
thanks!
#63
Unregistered Member
http://www.canadiantire.ca/browse/pr...romSearch=true
Ok i decided iam just going by another oil filter(sucks) but i just want my car to run well. So the link above is K&N just tell me if you guys approve of this.
#64
I use Royal Purple 5W-30 synthetic and Mobil 1 filter.
#65
Amsoil not only is the best oil, they also make the best filters. Why would you use anything else??![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
www.tsadvancedsynthetics.com/facts/EaOFilters.htm - 72k
http://www.wolverine-synthetics.com/...omparison.html
I bought the Mobile-1 filter and 5 quarts of Amsoil 5W-30 that I need to do soon. I will order an Amsoil filter for my next change.
#67
Amsoil and Royal Purple filters use a synthetic media. I have no personal experience with the RP filters but they look very promising.
The synthetic medias provide better flow (less chance of going into bypass), better filtration, and more loading capacity (longer intervals). They are also unaffected by moisture where a cellulose media will swell and not filter as well.
I leave my Amsoil filters on for 3 change intervals. It sounds crazy but it eliminates the dry start after each oil change. At 15,000 miles, it's nowhere near it's load capacity. I wouldn't think about doing that with a lesser filter.
Almost forgot, I use the Amsoil EAO 20 filter for the S-2000.
#68
if you're using synthetic, probably should use a better filter than oem. oem = meant for honda motor oil; more viscous than mobil 1 synthetic, royal purple, etc.
#74
Well I was using the Fram Severe Driving Filter since TLs go well beyond 3,000 miles according to the MID, but I guess I'll have to use something else from now on. I just changed my oil last saturday
#76
