Weird noise from front wheel
Hello all!!! New to the site after doing and getting alotta good info now this after days on here and googling buy a couple from Acura…new caliper pins and springs and I’m being quick here cause I’m trying to figure this out before I gotta go to work lol. This noise that sounded like pinging creaking started a couple days ago my friend that’s work on cars said it sounded like something from the brakes get hardware start there which seemed fair enough. I changed em out greased up the pads pins etc. the noise is still there. I thought it was a cv or something but the noise stays the same turning going straight etc and gets louder after I drive a little and things get warmed up. Any ideas what to check or anyone have this issue plz help!!!! THANKS IN ADVANCE!!! Posting the vids I think…I added the vids and put upload
so, now it's limited to the first 15 minutes. you can edit a post within 15 minutes. and I think there's a limitation on new users as well, so once you've become a vetted member, you're allowed to edit within that 15 min window
I was using my phone but I did hit the attachment button but I guess the file was too big but I had edited it. The upload button didn’t highlight and I got errors but I got it to work
yea that’s the same face I did changes the pins and spring took out pads slightly pushed pistons back check all bolts even the control arm we changed cause it looked a little worn…im at a loss right now lol
Problem solved something I was meaning to do anyway took off my spacers and boom all this stressful headache for something so simple…lol 🤦♂️
justnspace (06-20-2021)
Head a da Family
Have you checked the rotors for warping? You may have to have the rotors resurfaced. The lugs that hold your wheels in place are supposed to be tightened to 80 ft-lbs. Over tightening them with an air gun causes this problem.
nazTL
10-04-2016 05:12 PM
