Warped rotors...could Goodyear have caused it?
When I bought my TL about a month ago and had it inspected at the Acura dealer, brakes were fine, no shimmying when braking at highway speeds. About two weeks ago I noticed a nail in one of the front tires and brought it to Goodyear to have it removed because the tires were under warranty.
This past weekend, on a road trip up in the mountains, heavy, significant shaking/shimmying while braking at highway speed. Could Goodyear have caused this by not tightening the lugs to the correct specs? If so, do I have any recourse? Can I call them and ask them to pay for the warped rotors? I doubt it since I can't conclusively prove that it was their fault, but I thought I'd ask. What would you do?
Any advice is appreciated.
BANNED
^that sucks and yes it's entirely possible for the rotors to become warped if they tightened the lugs on too much.
you can take a shot and hope for some recourse but i would not get your hopes up because like you said, it's not like you can prove they're at fault for it.
the overexplainer
yep. If I ever have to go to a shop like that i watch everything they do.
it's a pet peeve of mine when i see them impact it on and then use a torque wrench to check...it defeats the purpose of the torque wrench if it's over tightened.
Former Sponsor
The factory rotors are prone to distortion. It is possible that if they over-tightened the lug nuts they caused the rotors to distort/"warp". If you replace the front rotors and pads I would recommend upgrading to a rotor that is less prone to distortion like the Powerslot slotted rotor. If you want better performance the STOPTECH Performance pad is a good option.
If you need pricing or links let me know. Or you can check our website in the sig below.
socal3 (05-30-2012)
Head a da Family
You have to watch whomever works on your car like a hawk when you go to these tire shops. I always make sure they use a torque stop when they use the impact wrench to put the lug nuts on. They must be tightened to 80 ft-lbs.
To the OP, it's possible in that a wheel that is not torqued properly can cause the rotor to not turn true and pad buildup can occur, but if you experienced heavy brake use in the mountains, that can cause pad transfer also, so no guarantee that is was an inproperly installed wheel.
If the wheel hasn't been touched since the install, check the lug nuts with a torque wrench with someone present to verify the readings and go from there, but even if it were found to be incorrect, it would be a difficult claim to prove as GY's stance would be someone else did an install in the time period that has elapsed. Guess it comes down to your word against theirs.
Although it might serve the purpose, that's not the proper way to repair a tire as any tire repair should be done after the tire is removed from the wheel.
Honda factory rotors warp easily. Nearly every Honda/Acura I've dealt with had warped rotors even if only a bit. Im talking cars with less than 100K driven by older people. On my buddies CR-V it was the same price nearly to buy new rotors. Mine warped at about 55K. I cut them down and havent had a problem yet but if it happens again I am replacing them.
The correct way would be to outright replace the tire or patch it from the inside but on a small scooter like that, the repair would cost more than the tire by the time you got it dismounted repaired and remounted so the $3 plug worked just fine......
i was just pointing out that the repair is more sturdy than what you make it out to be...... a vino rides on tiny tires inflated to about 40 psi....
it's a car-drive it
If the nail had been in the sidewall or to close to the edge the tiré place would not fix it. When we lived in Pa they use d plugs and many places in Nc use patches. The tiré place we went to has been around many years and was recommended to us.
http://www.fixtires.com/proddetail.php?prod=WW3
http://www.tirerack.com/tires/tirete....jsp?techid=77
it's a car-drive it
Not familiar with a "d" plug, but just to be clear, they should use a plug/patch to do the repair. It's not either or, it's a plug patch.
