Warming up your car...
Old Oct 9, 2008 | 01:54 AM
tl_rox's Avatar
Hey guys, i'm just wondering how long should we warm up our cars before starting to drive. (during summer time, rainy days, winter/snow) I get different inputs, and i'm wondering what you guys think? Thanks.
Old Oct 9, 2008 | 02:01 AM
ifirahse's Avatar
SlammedOnKonis
The way I do it is I wait until i can press OK on the nav screen and the map pops up, then i start to drive.
I'm sure others wait much longer.
Old Oct 9, 2008 | 02:35 AM
TheWanderer316's Avatar
'10 Shelby
As long as you don't drive the car hard, it should be fine. But i usually give it about a minute or two.
Old Oct 9, 2008 | 02:42 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
I think most people on the forum just crank up and go...I warm up for no more than 60 seconds. I believe the owner's manual states the same guideline, IIRC.
CBR2200's Avatar
2008 KBP Type S
No warm up is necessary. Just wait till normal operating temp for application of vtec.
Old Oct 9, 2008 | 03:27 AM
o4Komodo's Avatar
Rev High; Drive Happy
I personally wait half a minute... then drive [taking it slowly] until my temp-gauge is where it should be.
In winter time, in Montreal, that's a different story. When I crank, I sit there and wait till the car warms up. That is... if the roads permit me to drive.
Old Oct 9, 2008 | 05:50 AM
ChrisQ1980's Avatar
hates the winter
Turn the key to on for 10 seconds to let the fuel pump prime, start, let idle for 1 minute regardless of temp and then start to drive slowly and moderatly until the car warms up. This creates the least amount of wear, and uses the least amount of fuel.
Cars take longer to warm up when sitting wasting more gas, running colder longer means running rich. Just make sure oil pressure is up and circulating after one minute. The owners manual states to do this as well.
Old Oct 9, 2008 | 08:12 AM
vinnier6's Avatar
zero time....if i was a pussy, which i was when i lived in really cold winter times, i would start my car up and jack up the head and fix my coffee and then drive to work...this wasnt for the car, it was for me so i could drive to work in a warm car and not freeze my ass off on the way.....
Old Oct 9, 2008 | 08:43 AM
imj0257's Avatar
Q('.')=O
here in texas for 3/4 of the year is always hot/warm outside so i see no point in warming up the car. i just turn it on, wait 5-10 sec for the ac to kick in good and drive off.
however, in winter when it is damn cold, i will wait a minute or so til the engine and inside gets warm
Old Oct 9, 2008 | 08:55 AM
BASISON's Avatar
I usually start my car, wait for the "OK" on the nav screen, then drive...taking it easy until the temp gauge gets to normal operating temp.
Old Oct 9, 2008 | 09:04 AM
luckyAKAhappy's Avatar
My baby's ride...
No time waiting like the old carburated cars. Turn on and go.
Old Oct 9, 2008 | 09:26 AM
sixsixfour's Avatar
+1
when i get in, i buckle up, twist to the on, wait for the fuel pump "whine and click", start, and drive normally.
sitting and idling gives you zero MPG, as it takes longer for the engine to get up to temperature and you are going nowhere while doing so.
if you just get in, start and go (albeit normally), you do two things at the same time - warm up the engine (and all the other components like brakes, axles, transmission, etc) and actually get some miles per gallon burned. you also save time because instead of wasting a minute or two idling in place, you are actually moving towards your destination.
Old Oct 9, 2008 | 10:00 AM
LoveMyTL-S's Avatar
I also wait until after the Navi comes up. Then I'm gone!
Old Oct 9, 2008 | 10:10 AM
I hate cars's Avatar
I say it depends on what your morning drive is like. The old "most wear occurs at startup" is quickly becoming "most wear happens during oil warmup".
I wait a minute and then drive but I have 1.5 miles of residential streets so I can drive very easy at 25mph to get it up to temp. If I had to immediately make a freeway entry I would wait at least until the coolant is fully warm. Remember, engine oil takes about 15-20 minutes to get to full temp. Below 160 degrees the additives aren't doing much. I've seen charts on test engines where wear is 15 times greater with cold oil and it gets much worse when you put a load on it. In other words, 1 mile on a cold engine= 15 miles on a hot engine.
So let it warm for a minute or two and then drive as easy as you can until it's fully warm.
Old Oct 9, 2008 | 10:12 AM
BEAR-AvHistory's Avatar
I turn the key & go.
Old Oct 9, 2008 | 10:16 AM
JCharged's Avatar
Drive it like you stole it! LOL.
I usually have my car started before I head out the door. (5min span)
Remote start FTW!
Old Oct 9, 2008 | 10:40 AM
1995hoo's Avatar
Keep Right Except to Pass
I do this with one modification—I back out of my garage first (so as not to fill the garage with exhaust) and then I wait in the driveway until my garage door has gone down (I like to be sure that it doesn't unintentionally go back up, say if the electric eye sensor is out of position) and I've hit OK on the Navi.
If it's winter and I'm parked outside such that I have to scrape the windows, I'll usually turn on the car while I scrape. Thankfully that doesn't happen very often unless I go on a ski trip. While I know this wastes gas, the hot air and the rear defroster help with clearing the windows.
I read somewhere that one should never rev above 3,000 rpm until the temperature gauge reaches the normal level. That sounds about right to me. When I was in school in the mid-1990s I bombed down a highway onramp when the engine in my 1986 Legend was cold and when I reached my destination I noticed some steam coming from under the hood....popped the hood and found a blown coolant hose. Ever since then I take it easy until the engine warms up.
Old Oct 9, 2008 | 10:43 AM
xen-cuts's Avatar
ROFLCOPTER!
you can purchase an engine heater if you life in a cold area. I'm thinking of getting one. They are only $50.
Old Oct 9, 2008 | 10:49 AM
myron's Avatar
Yea in canada, we have an electrical plug ins if the parking lots are outside. I got an engine block heater and just plug it in and it keeps the engine nice and warm the whole day. Then I start the car and wait about 3-4 minutes for the heat and the seat warmer to start getting hot and I drive. But this is in -30ish celsius or lower weather. In the summer, like a 10 sec wait and drive
Old Oct 9, 2008 | 02:14 PM
The main reason to keep the revs down when cold is the oil is thicker and the filter and oil pump will go into bypass easier, allowing unfiltered oil through the motor.
Old Oct 9, 2008 | 02:49 PM
ABP_04TL's Avatar
6-SPEED LOVER
I wait at least 2-3 mins then ill roll slowly
Old Oct 9, 2008 | 03:24 PM
TeknoKing's Avatar
I give it one min, them slowly roll out, and then I'm off to the highway. Waiting longer just wastes gas, warm up the engine and go... To those who don't wait, just jump and go, you are wasting gas, a cold engine will use more gas. This is a fact.
Old Oct 9, 2008 | 03:58 PM
True with most cars, not so much the TL. It has to be in closed loop operation (feedback) within 10 seconds of startup. The mixture may be a little on the rich side but it's pretty close to stoich even when cold.
Besides, assume you are running rich, option A is to drive immediately to get the engine warm and out of enrichment as quickly as possible. Only problem is you're running rich not only at idle but when giving it gas to drive so consumption is magnified but for a shorter time.
Option B is to let it sit there and warm up. You're getting 0mpg but since it's at idle, consumption is less than .5 gal/hr.
I have no idea which uses less fuel but it's so minor, I choose engine life over potential fuel savings.
Old Oct 9, 2008 | 10:13 PM
Tripnbeats's Avatar
hmmmmmmmmmmm in case no one said it yet....read the manual....it tells u
Old Oct 9, 2008 | 10:52 PM
skyfox23's Avatar
Navi-screen boots up, push ok, then ease into it until the temp guage is where it usually is.
Old Oct 10, 2008 | 12:06 AM
Blazing GT's Avatar
Wait till the temperature gauge goes a little above C
Old Oct 10, 2008 | 12:30 AM
JwongTLS's Avatar
I let the car warm up for 20 mins,when the car is warmed up, I dont feel like going out anymore so I just turn the car off and go back home.( LOL JOKE)
Usually I jus let teh car warm up for about a min and smash off. Take it easy
Old Oct 10, 2008 | 12:39 AM
ifirahse's Avatar
SlammedOnKonis
Where should the temp gauge be resting at normally? I've always felt that mine shows a little low. It's about 3/4 between "cold" and the middle. Sometimes even only 1/2 way.
Old Oct 10, 2008 | 12:46 AM
EL Cubano's Avatar
Back for the first time
Remote start FTW!
Old Oct 10, 2008 | 01:44 AM
tl_rox's Avatar
Thanx guys for all the input...about "1 min." seems to be the popular answer. Thanx again!
Old Oct 10, 2008 | 01:47 AM
tl_rox's Avatar
Hey ifirahse...it should be resting normally at 1/4 way up from cold.
Old Oct 10, 2008 | 04:26 AM
ballerjai's Avatar
Make Nice, Not Rice
Turn on, press the "OK" prompt and on my way I go. Why wait? The engine warms up faster as you drive. Just don't rev past 5k, make it 4k to be safe and your fine.
Old Oct 10, 2008 | 05:07 AM
carlos9827's Avatar
2011 BMW 335i
I used to wait about a minute before take off but lately and only wait about 15-30 seconds and off I go.
Old Oct 10, 2008 | 06:49 AM
My baby's ride...
So does going over 55-60mph but we all know that is not the speed we drive on the highway. I think people wait because of premature wear on the engine as opposed to gas consumption.
I don't worry about premature wear as I never own any cars until they die. I'm on a new one way before then.
Old Oct 10, 2008 | 11:27 AM
designer's Avatar
In Canadian winters when it becomes -20C outside, I will literally let the car idle for 5- 10 mintues until the engine temp is almost at normal. Then I drive off slowly.
D
Old Oct 10, 2008 | 11:41 AM
TeknoKing's Avatar
Manual? Never heard of it... And when are you coming back already?!
Noroc!
Old Oct 10, 2008 | 03:39 PM
YeuEmMaiMai's Avatar
30 second to a minute in really cold (i meak like - temps) I give the car 2 mins when the temps are -15 or lower
Old Oct 10, 2008 | 03:46 PM
TeknoKing's Avatar
^ Usually in such cold temperatures, the car waits for me, until I warm up, lol.
Old Oct 10, 2008 | 03:55 PM
It's made to be a little under halfway to make the driver feel better lol. It takes a pretty good temp swing to get the needle to move from the middle. The guage is buffered so if it only runs a little hotter than normal the guage won't move and scare the driver. My guage stays the same from 165 to 199 degrees when I have a scanner on it.
Old Oct 10, 2008 | 03:59 PM
sixsixfour's Avatar
+1
if that needle worked like an aftermarket temp gauge, the dealership service would be packed with customers freaking out why their car's temp gauge is hitting red.
