Want to change my plugs at 64,000 miles advice
Order your plugs from advanced auto parts online then add 1 packet of anti-seize then enter the promo code BIG25. You'll get $25 off your order and you can pick up your order at the closest store near u
Your Friendly Canadian
Received 1,485 Likes
You do know your plugs are rates for 105,000 miles, right? That's why they're so expensive. There's no need to change them at 64,000, you've got a while.
Sure, but 40,000 miles in advance? Not getting anywhere near your money's worth, and any effects as far as engine life are concerned would only be noticeable at super-high mileage, as in 250k+, if that. Haven't heard of a TL failing because spark plugs weren't changed early.
B A N N E D
and money worth's i would say about 90k seems to be the tradeoff, but some people are willing to spend a little more to maintain it in tip-top shape
I changed mine pretty early (80k miles) and very glad that I did.
I definitely felt the difference.
I used OEM spark plugs bought from the dealer.
OP seems more concerned with cost than with perfect operation. In his case I'd say keep 'em, especially if the alternative is cheaper plugs.
FWIW I didn't really feel much of a difference when I changed my Iridiums.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
I guess so, part of it might be the trans fluid and oil change that were done at the same time. I just expected it to run better anyways, couldn't pinpoint the spark plugs as the reason
To the OP, Stick with the iridium tips; with platinum people have reported them lasting only 30K and as well giving poor fuel economy. One member had a CEL come on a while back. Furthermore, stick with NGK, Bosch ones for sure will throw a CEL and the Denso Plugs simply suck. You'd be lucky if the lasted 10K in the TL.
I changed mine at 106K. Can't tell one bit of difference. And yes, I'm very in tune with my engine...
Pull a plug or two and look at them. From my experience if they look like the ones in my picture, you're wasting your money. But if you insist, stick with the OEM plugs.
![](http://i263.photobucket.com/albums/ii154/jmillerl/sparkplugs1.jpg)
Boy you're stepping on thin ice with this crowd and I agree 100,000, is no problem for the OE Iridium plugs and there will be no improvement in performance when changing the plugs, unless one is fouled and not igniting, but for a normal running engine, no improvement.
From the NGK site:
Q: How much of a performance improvement can I expect from changing plugs?
A: A common misconception is that changing spark plugs will result in a large power increase. In most cases, removing even seriously worn out spark plugs will only result in very modest power gains, typically about 1-2% of total engine output. This could be even less for computer-controlled vehicles, primarily because most newer vehicles have more powerful ignition systems and the vehicle's computer can make adjustments so that vehicle operation seems smoother and more seamless.
Many people think that simply supplying more spark to the firing tip can and will combust more fuel. What they don't understand is that most newer cars' engines are so efficient that they are already burning all of the available fuel. Simply adding more spark voltage can't burn more fuel because there is no more fuel to burn.
When a stock or near-stock engine is given a fresh set of spark plugs, peak efficiency is restored. The power gains that come from this restored state of tune are usually minimal. Any company that tells you that their spark plug will provide significant gains in power in a stock or near-stock engine is making blanket statements that may not be supportable.
Yes the NGK platinum plugs will be cheaper and you can use them. Actually you can use a $2 or $3 plug and they will do the same job, just have to change out more often. I changed the spark plugs in my car at 88,000 miles and am glad I did. In fact I wish I had replaced them sooner. I like to know whats going on in the engines and changing out the plugs sooner will allow me to monitor things better.
06 Anthracite TL
I also subscribe to the fact that with a high energy ignition system, changing the plugs will result in no appreciable difference unless a plug was broken. I'm leaving mine in til 105,000 miles as recommended in the manual. These cars are so over-engineered that it makes no sense to spend money early to fix what doesn't need to be fixed. In the days of cars with points and condenser, which was a long time ago, you could feel a difference with changing parts of the ignition system, but these days, not at all. It's almost the same as when people change their oil and can feel a difference in how the car runs. The truth is that the car runs exactly the same.
I've posted this before, but due to my neglect, I didn't replace the OE plugs in the daughter's Maxima until 141,000 miles, no problems before, ran the same afterwards, and yes, they were the OE plugs as she purchased the car @ 27,000 miles.
Save your money unless one wants to pull plugs every 10k to see what they look like??????????????????????
B A N N E D
Most of it just depends on how the car has been treated in that past 60K or 90K or 105K. If folks fill up with 93 octane and keep the car's services on time (30K air filters, oil changes on time, etc) the plugs should have a minimal difference when replaced even at 105K. But if your putting 87 octane in and beating on the car constantly and not doing maintainance on time, then you probably are going to feel a big difference taking out worn, fouled up plugs out and putting in nice clean ones.
as far as Bosch plugs, the ones that come stock in german cars and such, not so much (and even then i think they have started to switch to Denso or NGK on quite a few of them), but aftermarket wise though, indeed they do suck ass
Denso's they are basically even or better then NGK, especially on certain application (ie: Toyota's)(which may not be ours)
also you realize that those brown marks on the porcelain, is combustion gases seeping past the "seal/metal piece" (idk what else to call it
From the NGK site:
From the NGK site:
OP, if you want to do something positive for the performance and longevity of your car and haven't already done so, I'd recommend making the switch to a good synthetic oil like Redline or Amsoil, or if you're looking for a local, readily available choice, Mobil 1 Extended Performance. It'll be a wiser use of your money, imo.
...yes they look "good", but what about the electrode gap, more then likely bigger then spec allows (look at how it even compares to the new one, quite a bit bigger by the looks of it)(and plug tips like that don't really show wear compared to the one's with bigger electrode)...
That's the #4 cylinder. If at 210K miles, the #4 plug looks the same, I may consider replacing that seal
B A N N E D
Nope, gap is perfect on the old plugs. I could not a fit 0.045" feeler gauge in any of the old plugs.
Sorry, afraid I must wave the BS flag on that one. If that was blow by, you'd expect the ends of my coils would be scored as well and they weren't. FYI, every picture of any plug pulled from a TL that I've ever seen shows the same brown ring/s. My old plugs were all well seated/torqued.
Doubt it, but possible that spark plug seal had a micro leak. In 106.5K miles and 14 oil changes, I never added a single drop of oil between my 7500 mile interval oil changes. In fact, the level never even reached 1/2 quart low on the "stick".
That's the #4 cylinder. If at 210K miles, the #4 plug looks the same, I may consider replacing that seal![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
it's not the threads which are blowing by, but between the components of the plug itself (and if you think about it the coil still sits above where those brown marks are, so the reason for not scorching your coils, they are higher up)
and oil in #4, it still has traces of oil though, may not be much, but still does (otherwise explain why no others have the brown on them at the hex section)(and it may only be a single drop every oil change, but still some leaking)
and here is another question for you, did you also adjust the valves for the 105k service? which would mean removing the valve covers, and replacing seals as standard practice (which would include that seal
![Teef](https://acurazine.com/forums/images/smilies/teef.gif)
sure looks bigger though...
The ends of the coils butt right up to that brown ring, so you'd think that they would be brown as well, but they weren't.
And...for reference, here's a pic of Majofo's spark plugs (from his DIY timing belt thread). Same brown rings. Guess we got us an epidemic on our hands, someone call a doctor
![](http://i263.photobucket.com/albums/ii154/jmillerl/sparkplugsmajofo.jpg)
Yep, did the valves and bought new seals, but woumd up not using them because all the original seals were in pristine condition...another reason I'm skeptical that that indicates a leak...We'll know in another 104K miles
AVB for President!
This is exactly what I did, although there is no brick and mortar store within 100 miles of where I live, so I had to get this shipped to me instead.
$48.22 after shipping and tax -- what a steal!![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
Comes out to $8.04/plug. Can't complain here!
I changed mine at 80,000 miles, after I had the car for 4,000 miles. I'm not sure if I could tell a difference, but its piece of mind maintenance. I would say 64,000 may be early, and definitely don't downgrade the plugs. Put the same thing in as what came out, which is NGK Laser Iridium plugs.
PS: Did other members torque them down to factory spec?
BobbyGraham388
10-22-2015 05:05 PM
