VSA Disengaging
VSA Disengaging
With increasing frequency the 'VSA off' warning has been appearing as I drive.
Shutting off/restarting engine will in some cases cure the problem, in other cases not, VSA will not reactivate.
Is this a known problem? Has anyone else experienced this problem? If so, what was the fix?
Thanks.
Thanks.
Go USC Gamecocks!
Thanks.
Thanks.
Acurich,
I had this same problem. The VSA was cutting off on me almost 3 times day. I would cut the car off and back on just to turn the VSA back on. I took it to the dealer and they found out there was a bad brake switch. They ordered the part and they fixed it in no time.
I also had them take a look at my front driver and passenger doors, as when I had the windows cracked or all the way down, I would shut the door and you could hear the windows rattling inside. They said I needed 2 new window channels for the doors. Back to the dealer again! BTW, this is the 3rd time at the dealer in a month and a half. But hey, I love a complimentary car wash! They always do a bang up job!
![Woot](https://acurazine.com/forums/images/smilies/woot.gif)
Chip
Thanks.
Thanks.
Maybe you are bumping the switch with your knee or accidentally hit it when adjusting the mirrors.
Go USC Gamecocks!
Originally Posted by utvol9903
Chip,
I wouldnt let them wash your car. They are leaving more and more swirl marks each time they wash it.
![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
Originally Posted by chipplaysdrums
Acurich,
Chip
Chip
KV
Originally Posted by kvan
I had the same problem. The VSA light would come on intermittently, then I started having problems shifting out of PARK. It turns out the brake/shift interlock switch was bad. They replaced the part...problem solved.
KV
KV
Thanks to everyone for their comments and suggestions.
VSA Fix
Hey, now that you mention it, I did have a bit of difficulty shifting out of park on one of the first occasions I experienced this problem. My hand slipped off the shifter, and I had to grab it & wiggle it around a bit to get it into drive.
Problem solved.
Silver lining, I had two days in an MDX loaner. Very impressed, particularly with the TOTAL lack of annoying interior snaps, krakles and pops, despite cold weather.
Just goes to show that with a bit of development, Acura CAN produce a vehicle without these annoying interior noises inherent in the TL, at least in my early build 04.
Jamus22
06-11-2023 10:08 AM
spoiler900
10-10-2015 06:48 PM
