visor rattle
One on the right for me
visor rattle
does anyone notice that the mirror cover on the driver side visor rattles when it is down? it seems is if the entire flap is loose. on my 00 tl its hinged in place so no chance of movement, but on the 04 it does not appear to be secured at all.
Not a Blowhole
Team Anthracite Member
I really do not believe it is the lid. As I posted before it appears to be the vanity light in the headliner hitting the mirror cover. Pull your visor down a bit or put some material between the light and the cover to see if it goes away. Many times people mistake that one for a dash rattle. My S2000 did it as well, it took me close to a year to figure it out...
Team Nighthawk President
I used little self-stick rubber bumpers on the mirror. They're exactly like what you see in the corners of the doors of kitchen cabinets to keep the door from slamming. I used them in a few strategic locations throughout the interior to eliminate buzzes and other noises. You can get them in Home Depot, probably right next to the felt ones. The reason I used the rubber is that the felt was only available in green, while the rubber is clear and you can barely see it.
I also put little rubber stops on the corners to get rid of the rattle. The funny thing about this is that Acura have the same visors in the TSX but they put factor installed rubber pieces on the TSX, go figure.
someone elses Avatar?????
this happens when i put the sun visors up against the winshield to block the sun, it is so damn annoying, putting in the felt/rubber tabs in asap
I bought clear plastic rubber dots. They look much better than black rubber or felt. I bought them at the local hardware store and they stopped the rattle. They look like they came from the factory BTW, being clear, you don't even notice them.
never thought about buying clear ones, thanks I think I just might do that .
I have both the mirror cover rattle against the vanity light as well as the previously mentioned right-side clip rattle... how did you get rid of the clip rattle? It is the piece that is connected to the headliner that is not secured firmly in place for me. Hoping to fix both this weekend....
marcelft
07-10-2018 06:17 PM
SUPRMN84
10-07-2015 09:46 PM
jaynatlanta
5G TLX Problems & Fixes
09-15-2015 11:08 AM
