Vibration, Drone, Exhaust Resonance... whatever it is...
Old 02-13-2004 | 01:53 AM
rets's Avatar
Moderator Alumnus
Question Vibration, Drone, Exhaust Resonance... whatever it is...
Since more and more ppl talking about the exhaust resonance could be one of factors causing this 1500 rpm vibration, I saw this over TOV, posted by sparkyg,
I have some experience with the drone on a 2004 MDX. The whole vibration in the floor and drone at 2000 RPM (for the MDX) was a result of poor exhaust isolation from the vehicle. Acura has acknowledged the problem and are issuing a TSB on the change. As a short term fix the dealer removed the rubber hanger from the first muffler and added spacers to the bracket on the very front exhaust near the flexible coupling. These changes removed the drone and the vehicle was perfectly quiet.
I got the tip from acuramdx.org. I know the drone has been very well reported on many links but I am not sure if this fix has been tried. I know some owners tried changing the exhaust system, so too did some MDX owners and the noise persisted. The rubber isolators just do not seem to do good job isolating the vibration/noise. On the 2004 MDX there was also some welded weights on the main exhaust pipe that was possibly Acura's attempt at a fix to try to change the vibration/resonance of the whole exhaust system. The 2003 models did not have this little engineering afterthought. I can understand everyones frustration and I hope to see a fix soon given my pending purchase of a TL this spring.
Cheers!
What do you think? Anyone heard this story from dealers before? Thanks.
Old 02-13-2004 | 07:13 AM
Norse396's Avatar
My car doesn't have this problem, but for others that do your advice sounds like it would work.
Old 02-13-2004 | 01:04 PM
rets's Avatar
Moderator Alumnus
The problem is dealers won't start to try this unless receiving the TSB or Advisory information from Acura.
I just wonder if anyone ever tried this by their own cost.
Old 02-13-2004 | 04:57 PM
Tread's Avatar
Correct, dealers will not play with the mounts unless Acura authorizes them to do so, or it is paid for by the dealer.
Old 02-15-2004 | 12:27 AM
boringegg's Avatar
i've got this 1.5k-2k rpm vibration issue too..
Old 02-15-2004 | 04:04 PM
rarely registered user
I've got the problem too. I found that the best solution is to turn the radio up and pretend it's not there.
MrHeeltoe
20
02-23-2023 01:54 PM
DerrickW
11-15-2015 05:52 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: Vibration, Drone, Exhaust Resonance... whatever it is...
