Upgrade '08 OEM tail-lights to '08 Type-S OEM tail-lights
Old 09-07-2009 | 07:25 PM
Polo8385's Avatar
3rd Gear
Post Upgrade '08 OEM tail-lights to '08 Type-S OEM tail-lights
Can you upgrade 08' OEM tail lights to '08 Type-S tail lights? if so, is it easy to change? Are there instructions online on how to replace the tail-lights?
Old 09-07-2009 | 08:51 PM
TheChamp531's Avatar
Chapter Leader (San Antonio)
Yes it is a direct fit. It is farely easy to change as you will have to remove the rear bumper to put it on. Check the 3G garage and you'll get all your information and DIY (Do it yourself) in there.
Welcome to Acurazine!
Old 09-07-2009 | 10:00 PM
AckTL05's Avatar
Former Sponsor
it is easy, ive changed my 05 tails with the tl-s. easy just time consuming takng off the bumper and such but other then that its simple.
Old 09-08-2009 | 02:45 AM
ballerjai's Avatar
Make Nice, Not Rice
Yup, definetely doable!
Old 09-16-2009 | 11:31 AM
Bubz's Avatar
SSgt. Hood
Yes x 5
Old 09-16-2009 | 11:36 AM
LoveMyTL-S's Avatar
You got your answer but wanted to welcome you to AZ
Old 09-16-2009 | 12:06 PM
rockstar143's Avatar
you do not need to take OFF the rear bumper...just the sides and top part to access the two bolts holding the bottom of the lense.
then unscrew and pry back the liner from inside the trunk to reveal the 4 small nuts...unplug the lights...take off car...swap out LED board (unless you're a baller and bought new ones) and install new lights.
An hour job if you have the skill and tools and you're taking your sweet azz time.
BoricuaTL
04-08-2016 01:08 PM
handsom-hustla
11-13-2015 05:04 PM
Jpro
09-13-2015 07:14 PM
MyKids&Cars
09-01-2015 12:53 PM
Quick Reply: Upgrade '08 OEM tail-lights to '08 Type-S OEM tail-lights
