TSB & VIN
Old 12-02-2005, 04:20 PM
  #41
Administrator
Ron A's Avatar
Received 1,003 Likes on 573 Posts
TSB 05-043: Safety Recall: Right Front Impact Sensor Is Loose
Ron A is offline
Old 12-02-2005, 04:21 PM
  #42
Administrator
Ron A's Avatar
TSB 90-009: Automatic Transmission In-Warranty Exchange Program
Ron A is offline
Old 12-02-2005, 04:22 PM
  #43
Administrator
Ron A's Avatar
TSB 98-015: Special Tool Loan Program
Ron A is offline
Old 01-18-2007, 10:23 AM
  #44
Administrator
Ron A's Avatar
Originally Posted by Thomwarn
Dumb question.... What's all the chatter re: vin numbers, is it the last four digits that signify when it was built, and the higher the number means later production? If so, from what VIN number did some of the early problems get ironed out?? Thanks for the help!
EL42 Tire Vibration Work Sheet
TSB 88-016: Battery Test Procedure.
TSB 89-015: ATF Cooler Cleaner.
TSB 96-009: Removal of Clear Guard Protective Film.
TSB 96-025: Navigation System Component In-Warranty Exchange/Out-of-Warranty Repair.
TSB 97-040: Keyless Remote Transmitter Information.
TSB 99-010: Cutting Keys With the Exacta Key Code Cutter.
TSB 00-037: Brake Disc Refinishing Guidelines.
TSB 01-026: Updating the ECM/PCM (Revised 20 Sept 2005.
TSB 02-020: Initializing the OPDS Unit.
TSB 03-012: Immobilizer System (Type 4).
TSB 03-013: TQI of the DVD Navigation System With Voice Recognition.
TSB 03-023: TQI and New Model Information.
TSB 03-024: 2004 Acura Paint Codes.
TSB 03-033: MIL Comes On With DTCs P0301, P0305, and Possible P0300
TSB 04-004: Updating the Honda Interface Module (HIM) Model 3557-0100-00
TSB 04-005: Driving Position Memory System Does Not Work.
TSB 04-006: Audio Unit Diagnosis. (Revised 10/19/2005)
TSB 04-015: ABS Indicator Comes On With DTCs 15, 16, 17, 43, and/or 44.
TSB 04-016: MIL Comes On With DTC P2195 or P2197.
TSB 04-019: Brembo Brakes Squeal With Light Application.
TSB 04-020: Safety Recall: CL and TL Automatic Transmission 2nd Gear Inspection.
TSB 04-034: Moonroof Wind Deflector Rattles.
TSB 04-036: HomeLink™ Unit Does Not Learn The Garage Opener Code
TSB 04-039: Headliner Sags at Moonroof Opening.
TSB 04-043: Rear Shelf Rattles.
TSB 05-003: 2005 Acura Paint Codes
TSB 05-013: Safety Recall: Fuse Box May Cause a No-Start or Stalling Condition.
TSB 05-014: Child Seat Anchor Locating Button Is Missing (Revised 06/07/2005)
TSB 05-016: Roof Console Bezel is Cracked or Broken
TSB 05-017: 5th Gear Vibration or Drone.
TSB 05-018: Navigation System DVD Information
TSB 05-020: HandsFreeLink (HFL) System Does Not Work (Revised 09/23/2005)
TSB 05-025: Outside Air Temperature Gauge Reads Inaccurately
TSB 05-029: Product Update: DTC B1161 with Outside Air Temperature Displays Three Dashes (- - -), or Intermittent Dead Battery
TSB 05-032: 2006 Acura Paint Codes, Exterior and Interior Color Code Locations (Revised 2/10/2006)
TSB 05-033: Power Mirrors, Auto Dimming Mirror, Power Seat Position Memory, and Windshield Washer Do Not Work (Revised 10/14/2005)
TSB 05-034: 2006 TL: TQI and New Model Information
TSB 05-050: Premature Rear Tire Wear (supersedes TSB 05-076)
TSB 05-076: Premature Rear Tire Wear (superseded by TSB 05-050)
TSB 06-009: Power Window Main Switch Button is Damaged or Missing
TSB 06-012: Inside Rearview Mirror Is Loose
TSB 06-013: Long Crank Time or Hard Starting
TSB 06-023: MIL comes on with DTC P0116
TSB 06-024: High Mount Brake Light Cover Material Comes Loose
TSB 06-031: Front Door Glass Makes Noise or Stops When Going Up or Down
TSB 06-034: Vehicle Pulling or Drifting
TSB 06-035: 2007TL: TQI of the DVD Navigation System with Voice Recognition
TSB 06-036: 2007TL: TQI and New Model Information
TSB 06-040: Glove Box Rattles or Squeaks
TSB 06-050: Warranty Extension: Vehicle Warranty Mileage
Edit by MODS rets and Ron A
posting this for backup in case the links to the posts in this thread are needed later on, since I am changing the links to the honda pubs links 1/17/2007. More links are in word documents.
Ron A is offline
08_UA7_Gr33k
02-11-2016 02:17 PM
lanechanger
10-13-2015 10:56 AM
thegipper
09-28-2015 01:01 PM
jmaxima03
09-27-2015 10:22 AM
JOE COOL
2G RDX Problems & Fixes
09-24-2015 07:15 AM
Quick Reply: TSB & VIN
