TSB Tracking
TSB Tracking
All,
How about if we use this thread to track Technical Service Bulletins (TSBs) for the 04 TL? This way when you go into your dealer's service dept. you can reference a known and documented problem and a lazy tech. won't be able to dismiss your problem with a lame comment like "we're not aware of any problem with the _____" or "no one else has mentioned _____ as a problem, you're the first". :banghead:
So, anyone who has a problem fixed please inquire as to whether a TSB existed for the problem and what the ID # is then post that number here. I myself am interested in the fix for the seat memory problem and hope to get that fixed when I go in for my first oil change.
need4spd, mengle - any upd. with supposed fix for seat memory loss?
KNOWLEDGE IS POWER!
KNOWLEDGE IS POWER!
RJC RSX, I started to poke around the site you provided a link to above and got this in pop-up window:
IMPORTANT NOTICE
The American Honda Motor Company, Inc. has requested ALLDATA restrict access to Acura and Honda repair information by individual consumers. You will unfortunately not be able to register for access to Acura or Honda vehicle repair information, technical service bulletins or recalls.
We kindly request that all comments should be directed to:
American Honda Motor Co., Inc.
P. O. Box 2206
700 Van Ness Ave.
Torrance, CA 90501
Honda: 800-999-1009
Acura: 800-382-2238
Please accept our apologies for any inconvenience this may have caused you.
What's up with this???
All the more reason to get the TSB #s from techs. who are willing to spread the word...
IMPORTANT NOTICE
P. O. Box 2206
700 Van Ness Ave.
Torrance, CA 90501
Honda: 800-999-1009
Acura: 800-382-2238
Moderator Alumnus
Sounds like Honda/Acura worry about the coming-soon TSBs would hurt their sales. Or, they just try to prevent any individual using those data inproperly.
Or, Acura is gonna announce tires/vibration/Seat Memory issues soon, and don't want this damage their sales of 04TL...
What other car makers do with this? I guess you have to pay to get those after paying money?
Moderator Alumnus
Re: TSB Tracking
enorton,
You should collect at least one TSB-like info, and ask Mod to have your thread sticky. Good idea to have all TSB and Advisory-info togetehr...
Then, you can add them on when collecting more and more...
Cesspool of Knowledge
Geeez, guys -
If you want TSBs, why don't you go to the real source?
The Real Source
Ain't the Internet a wunderful thang?
Oh, and by the way - As of today (24-FEB-04) there are now 3 TSBs for the 04TL.
And, only one of the things that people whine about in this forum are in the list (You get to find it on your own via the website. I don't want to spoil the surprise!)
Now we have two new things to whine about, too!
The Real Source
¿GotJazz?,
That's Great! I'm no fan of reinventing the wheel! As you can see earlier in this thread I attempted to go to a TSB site that another member suggested but it didn't work....but your site does! Thanks for the info...
Moderator Alumnus
Originally posted by ¿GotJazz?
Geeez, guys -
The Real Source
Geeez, guys -
The Real Source
I knew this, and felt confused sometimes.
For example, lots of early built cars have to upload the new ECU software in order to correct MIL ON issue. When I did this, I saw the service-advisory info in my dealer. But later, more and more ppl have confirmed there is TSB for this issue now. This isn't in the NHTSA sites yet.
Maybe Acura has another system to store TSBs.
Moderator Alumnus
TSB: VISIBILITY:DEFROSTER/DEFOGGER SYSTEM:WINDSHIELD:CONTROLS/WIRING...
Make : ACURA Model : TL Year : 2004
Service Bulletin Num : 1003 Date of Bulletin: OCT 16, 2003
NHTSA Item Number: 10004960
Component: VISIBILITY: DEFROSTER/DEFOGGER SYSTEM:WINDSHIELD:CONTROLS/WIRING
Summary:
HEATER BLOWER MOTOR OVERHEATS OR BLOWS FUSE. *TT
Summary:
Moderator Alumnus
TSB: SERVICE BRAKES, HYDRAULIC:FLUID...
NHTSA Item Number: 10004959
Component: SERVICE BRAKES, HYDRAULIC:FLUID
Summary:
TESTING BRAKE FLUID FOR PETROLEUM CONTAMINATION. VARIOUS MODELS INCLUDING 2003 AND 2004 NSX AND 2004 RSX. *TT
Summary:
Moderator Alumnus
TSB: STRUCTURE:BODY...
NHTSA Item Number: 10004963
Component: STRUCTURE:BODY
Summary:
GLOVE BOX HOUSING REMOVAL AND REPLACEMENT TIP. *TT
Summary:
TSB: VISIBILITY:FOG LAMPS
SYSTEM:LIGHTING:AUXILIARY/FOG...
Service Bulletin Num : 1009 Date of Bulletin: FEB 24, 2003
NHTSA Item Number: 10004799
Component: VISIBILITYKFOGLAMPS
SYSTEM:LIGHTING:AUXILIARY/FOGLAMPS
Summary:
FOG LAMPS MOUNTED TOO HIGH TO BE CONSIDERED "REAL" FOGS. *HD
Summary:
Moderator Alumnus
Finally, I don't know what they are. My stupid dealers never told me anything about them...
Is Anti-freeze smell from AC/VENT related to "VISIBILITYEFROSTER/DEFOGGER SYSTEM:WINDSHIELD:CONTROLS/WIRING"?
Is rattle of Glove box relevent with "GLOVE BOX HOUSING REMOVAL AND REPLACEMENT TIP. *TT"?
Mike
Re: TSB: VISIBILITY:FOG LAMPS
Summary:
Summary:
Moderator Alumnus
Thanks, Mike,
I removed them and did put the felt/tape to stop rattle, yes, I do hear ppl saying the dealer usually will order the new clips to re-install the glove box back...
Retired MOD
1 Post
Geeez, guys -
The Real Source
Geeez, guys -
The Real Source
Team Camel, VP for Zaino
03-033
MIL Comes On With DTCs P0300, P0301, and P0305
The MIL is on, and DTCs P0300 (random misfire),
In the ECM/PCM software, the parameters for
monitoring misfires at high RPM are too narrow,
Use the Honda Interface Module (HIM) to update the
In warranty: The normal warranty applies.
Failed Part: P/N 37820-RDA-A51
Out of warranty: Any repair performed after warranty
expiration may be eligible for goodwill consideration by
the District Parts and Service Manager or your Zone
Office. You must request consideration, and get a
1. Connect the Honda Diagnostic System (HDS) to
the DLC (data link connector), and check for DTCs.
• If DTCs P0300 (random misfire), P0301, and
• If another DTC is also stored, refer to the 2004
TL Service Manual for the appropriate
Originally posted by Bitium
Don't they only post safety related items.
I think their safety stuff ia in a "Product Recalls" area.
Moderator Alumnus
Originally posted by UminChu
This thread seems suitable for a sticky?
My suggestion is to create another new Thread and put them in again if you need "sticky" with it.
Because I have destroyed this one. My bad. :o
Moderator Alumnus
Some early built car, VIN# under 12xxx (or 14xxx, sorry, don't remember), their MIL (Maltifuctional Indicator Lamp, so-called the check engine light) will flash frequently when you rev your engine high, especially when you rev over 4k RPM. That light will keep flashing until you slow down.
Acura finally addressed this issue in Dec, and inform dealers of this update. Dealers could use the new software to update your ECU and make it less-sensitive. Someone also changed their craft sensors or other components at that time.
But this had caused some big mess in Oct & Nov. Lots of ppl had this problem, but no one knows how to fix it.
My stupid dealer even told me in Nov that Check-engine-light is NORMAL, it indicated your car required up-shifting to the next gear. #W%UW$##...
Hope this could help...
emailnatec
29
09-28-2018 04:27 PM
