Tru Bendz products
Tru Bendz products
I was interested in buying a good exhaust system for my car and happened to come across a site called TruBendztechnology.comhttp://www.trubendz.com/products/04-08-acura-tl-dual-exhaust-tubing-2-5-inch-aluminized.htmlthat was selling exhaust systems for $170- $270 price range and when I saw that the first thing I thought immediately was that it's a steal but then again I don't know just how great these exhaust systems are in improving performance and giving you power. Has anybody here ever purchased or has had anybody experience with their products, and if so how would you rate them?
you get what you pay for
So I would have to set the actually have to set the metal in a way that it would fit my car, I see what your saying.
Oh ok sorry for the misunderstanding. So around how much do you think I should expect for this work to be done?
last time I went to a muffler shop, they had like 25 different exhaust tips on display, and had more available beyond that. You could make a nice looking exhaust. Would it be as nice as ATLP, RV6, or XLR8? No. Definitely not. But for the cost, I don't think you can really go wrong. I wouldn't do it on a new car, but a 10 year old TL? I'd consider it.
Also, if I'm not mistaken, the brands like ATLP, etc., use some high quality stainless steel piping... On a new(er) car? Fuck yeah. Otherwise... All you're doing is preserving it from rusting... Too bad the car itself will likely start rusting before that. Because older Honda.
Trubendz offers stainless steel as well. I think the best part of trubendz is the option to have full 3in, or 3in to the split and 2.5 after. Great for FI cars. In any case, I would suggest the aluminized to save some money over the stainless, and build an exhaust yourself. Sure, if you go to a regular muffler shop it won't be tig welded and look like art, but its under the car - as long as it functions properly and sounds good, I'm cool with it.
Trubendz is only selling the pipes! Looks to be the same pipes as included on the Endless RPM exhausts.
No flanges on the front end to connect to Jipipe or on the ends to connect to mufflers!
You will need to supply your own muffler, resonator (if needed) and tips along with flanges.
Mufllers are going to be $100 each, $25 for tips and $25/flange. Going to be spending over $500 all said and done. A shop local to you can do everything cheaper than trubendz.
I also wanted ask a question regarding the sounds that come from the muffler. Does anybody know a good muffler or exhaust system out there that will make an aggressive growl when gas pedal is pushed but at the same time won't take away from the quiet ride inside the interior cabin?
