transmission fluid slightly above the 2nd dot, ok?
is it ok if the transmission fluid is slightly above the 2nd dot? the manual say the fluid should check between the 1st and 2nd dot (hole) from the bottom of the dipstick.
if its not ok, can i stick a small tube down the dipstick and reverse the fluid back out?
It would be an AT, manuals don't have a dip stick to check levels. If your talking like 1/8th inch or less above the second dot I wouldn't worry but you don't want too much oil in there, my understanding is it can get mixed around too much and start getting bubbles/foam which doesn't lubricate as well when pumped around.
Your checking the fluid with the vechile running and on a level surface? I don't know if they are supposed to be checked in Park or in Neutral?
LIST/RAMEN/WING MAHSTA 짱
You're fine but if you want to extract a little the best way is to do it through the dipstick. Totally not necessary in your case though. Check the fluid on level ground within a minute or so after the car has been turned off.
You of all people..
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
Mike Bertram
09-10-2015 09:27 AM
