TLS foglight question
TL Type S
Hi
I am about to upgrade the foglights to HIDs
I understand that the foglight on 07 TLs are 35Ws.. HID uses 35W, but uses 65W to start up.
Will this damage my wires? or are they capable of handling 65W?
Thanks in advance!
Gabriel
Thanks in advance!
Gabriel
You may want to get more opinions on this...I could be wrong....I just know that when I wanted to replace my headlight unit on my Mercedes ML with a HID unit, MB dealer said I couldn't just swap out the units but would also have to have rewiring done to handle that high startup output the HID's required...but more recently they've come out with converters so you don't have to replace all the wiring, instead just use the converter to bridge the HID to the existing wiring
(apologize about the lengthy/confusing explanation)
Terminex
Yes and No
Originally Posted by Doridori
Hi
Thanks in advance!
Gabriel
Thanks in advance!
Gabriel
The best way to go is simply to buy a conversion kit that will provide the appropriate bulb, ballast, ignitor (starter), and wiring.
I have done many of these with no problems.
NOW, be warned
If you have problems this will voide the warranty related to those lights, and any of the wiring for them.
SidhuSaaB
05-30-2020 12:40 AM
Pham Alvan
03-16-2016 09:17 AM
navtool.com
31
11-16-2015 08:30 PM
