TL Halo help
^As far as I can remember, no, there isn't. Although I can't see it being very hard. Bake, drill, glue halos, run wires, bake / put back together, additional sealant, wire in engine bay, done? About right? Anyone?
Also I'm curious as to what sizes and kinds people use. I think for my 04 I would need 80mm. I was looking at oznium but I know umnitza is used a lot too. What I don't understand is how is umnitza $130 and oznium $25?
should I just stick the halo rings with like krazy glue?
I found clearing instructions for the opening of the headlight. I guess just bake it for 20 mins at 200 degrees and then the lens should just pop off.
I don't know about "popping" off, but yea, 20 minutes @ 200*.
I baked my preludes taillights, and it was kind of a bitch. Get it hot, mess with it, then it needs reheated, mess with it, etc.
As far as mounting the halos, I imagine people are using JB Weld or the like...super glue may work too.
1 Post
secondtonone...... contact the member on Acurazine named JnC... he does headlight mods for a little over $100 and his work is flawless. I would say the best money you can ever spend on your TL. Just my
dlknight
09-02-2015 10:42 AM
hinduluv
01-24-2005 08:49 PM
