TL Fuel Mileage
TL Fuel Mileage
I know there are a few threads on this, but I wanted to post my recent mileage from a road trip from Atlanta, GA to Boca Raton, FL. The TL never ceases to amaze me with a perfect balance of sport and luxury, power and economy, flash and subtlety. The keys to the ridiculous 35MPG were:
1. Cold Air Intake
2. Tires inflated 6 PSI over recommended 32
3. Very close drafting to Semi Trucks (within 3 feet of their bumper, which is probably not the safest thing!)
4. Avoid hitting the brakes at all costs
5. Build up momentum and apply gas going down a hill, and coast up the hill (combustion engines are much more efficient under low stress)
6. Keep a reasonable, steady speed (65 or so)
Oh, and if I didn't mention yet, I LOVE THE THIRD GEN TL!!!!!!!!!
http://www.facebook.com/editalbum.ph...&id=1273302088
1. Cold Air Intake
Unregistered User
1. Cold Air Intake
1. Cold Air Intake
On long drive i floored by TSX as much i want permitting traffic conditions with speeds between 1.5 to 1.8 times yours still getting between 32 to 35mpg. Wind/Tire/engine noise is completely hushed.
If you drive a car like Grandma to achieve fuel economy on long drive. It is definitely not economical car.
TL. It wasn't really for cost savings or anything like that, just for the heck of it. I will be driving like a "normal" person on the way back up to Atlanta today, and will see what the results are.
1. Cold Air Intake
1. Cold Air Intake
2. Perhaps, but dangerous for a number of reasons outlined here, here, here, discussed here, and just google this.
3. and 4. You're kidding right? Particularly #3.
5. and 6. Good advice.
Ha! I am by no means saying the TL is an economy car, it just has nice balance of power and economy. Anyway, the trip down to Florida was really used more as an experiment to see what kind of mileage I could get out of the
Its true TL can get 0-100mph in 16 to 17 seconds and TSX will take 19 to 20 seconds.
but what difference couple of seconds makes in 5 to 10 hr long drives. when you cannot floor TL as much as TSX. it is the scream of VTEC engine in sports mode that i like the most.
A lot of trouble for an extra 10%
1. Cold Air Intake
1. Cold Air Intake
1. Keep speeds reasonable (< 80 MPH) and stable
2. Keep a SAFE distance behind car ahead of you so you simply coast when you see brake lights instead of slamming on the brakes every time the the car ahead of you has the brakes on.
3. Don't use Cruise on hills or traffic conditions. It guns the motor on hills and doesn't allow for #2 above.
I would expect the TSX to get about 20% better economy simply because it has 20% less displacement and 1/3 fewer cylinders and less weight too. I think the TL is very efficient for the type of car it is.
Registered Member
The best mileage I have recorded on a road trip was in September '05. A/C was used the entire time (outside temp was 86) and the traffic was moderately heavily. Speeds ranged from 62 to 78 MPH. I did none of what the OP did and managed 33.94 with my '04 manual TL.
I can easily acheive 32MPG with a loaded car (4 passengers) with luggage going 70-75MPG with just a few simple techniques:
They have about same interior space.
2G TSX Navy Auto weighs 3500lbs. 3G TL about 3650lbs.
If i am not mistken 2G TSX has bigger Gas tank of 18.5 gallons.
201 bhp vs 258 bhp.
TL 232 ft-lb torque is produced higher in rpm range
Its plain simple which one is more efficient design for sustain higher speeds and less time at gas pump. i was doing 3400rpm @100mph. Only 2500rpm @80mph.
this thing is for those who make purchase decision between similar priced 08 TL and 09 TSX.
I was curious about your statement that the 2G TSX is the same size inside as the 3G TL. Some of the specs I read on Edmunds dispute this.
TL Wins
Wheelbase (this affects interior space and handling):
TL: 107.9 TSX: 106.6
Front Head Room:
TL: 38.7 TSX: 37.6
Rear Head Room:
TL: 37.2 TSX: 37
Front Shoulder Room:
TL: 58.3 TSX: 57.8
Front Leg Room:
TL: 42.8 TSX: 42.4
Rear Leg Room:
TL: 34.9 TSX: 34.3
TSX Wins
Rear Shoulder Room:
TL: 55.6 TSX: 56.1
Rear Hip Room:
TL: 53.8 TSX: 54.2
Same in both cars
Front Hip Room
TL: 56.2 TSX 56.2
Does anybody have a spec for total interior space (cubic feet) for the 2 cars?
Seems to me the 3G TL is bigger inside, but the new TSX is pretty close.
TL Wins
Front Head Room:
TL: 38.7 TSX: 37.6
Rear Head Room:
TL: 37.2 TSX: 37
TL: 58.3 TSX: 57.8
Front Leg Room:
TL: 42.8 TSX: 42.4
Rear Leg Room:
TL: 34.9 TSX: 34.3
TSX Wins
Rear Shoulder Room:
TL: 55.6 TSX: 56.1
Rear Hip Room:
TL: 53.8 TSX: 54.2
Same in both cars
Front Hip Room
TL: 56.2 TSX 56.2
TL Wins
Front Head Room:
TL: 38.7 TSX: 37.6
Rear Head Room:
TL: 37.2 TSX: 37
TL: 58.3 TSX: 57.8
Front Leg Room:
TL: 42.8 TSX: 42.4
Rear Leg Room:
TL: 34.9 TSX: 34.3
TSX Wins
Rear Shoulder Room:
TL: 55.6 TSX: 56.1
Rear Hip Room:
TL: 53.8 TSX: 54.2
Same in both cars
Front Hip Room
TL: 56.2 TSX 56.2
TL Wins
Front Head Room:
TL: 38.7 TSX: 37.6
Rear Head Room:
TL: 37.2 TSX: 37
TL: 58.3 TSX: 57.8
Front Leg Room:
TL: 42.8 TSX: 42.4
Rear Leg Room:
TL: 34.9 TSX: 34.3
TSX Wins
Rear Shoulder Room:
TL: 55.6 TSX: 56.1
Rear Hip Room:
TL: 53.8 TSX: 54.2
Same in both cars
Front Hip Room
TL: 56.2 TSX 56.2
Headroom matter but there is hair splitting difference. Car can have acre of useless space behind the rear seats or dashboard.
2G TSX has more frontal width and height than 3G TL.
201 bhp vs 258 bhp.
201 bhp vs 258 bhp.
While the TL has the 22% larger engine, higher horsepower and better 0-60 performance it gets within 10% of the mileage. For people like myself, it was a no-brainer picking the TL over the 1st-gen TSX. The 2nd gen TSX makes the decision a little tougher, but I would still pick a 3rd gen over the TSX especially with the current gas prices low like they are now.
The 2nd gen TSX is definitely larger and closer to the TL in size. One way to compare size is using Passenger volume in cubic feet. The 3rd Gen TL has 98 .vs. 2nd gen TSX with 95 .vs. 1st gen TSX with 91 based on fueleconomy.gov. Quoting MPG at 100mph is completely irrelevant in the US and has more merit in Europe than here. FuelEconomy.gov reports average real world mileage as follows: TL MPG at 22.4 MPG, 2nd gen TSX at 25.3, and 1st gen TSX at 28.4. So the TSX actual mileage appears to have dropped a bit- presumably due to the increase in size and weight. The big improvement for the 2nd gen TSX is the carbon footprint which decreased to 7.3 from the 1st gen's 8.0! The TL has a 8.7 carbon footprint (tons of CO2)
New TSX is more economical when it is broken down.
Auto TSX is more economical than manual TSX.
1G TSX achieves 0-100mph in 19.5 seconds.
2G TSX achieved 0-100mph in 18.8 seconds (despite having heavier and larger car with less peak power)
3G TL 2004 achieve 0-100mph in 15.9 Seconds. I think 08 TL is heaver than 04 TL.
2009 TSX.
http://www.roadandtrack.com/article....rticle_id=6833
2004 TL Manual
http://www.roadandtrack.com/assets/d...2004172540.pdf
2004 TSX Manual
http://www.roadandtrack.com/assets/d...subaru-pg1.pdf
04TL/SSM/Quartz/AT/Navi
I have around 51,000 miles on my '04 with Auto.
Highway Mileage
On trips is usually 34MPG. Typically have the A/C off (weather permitting, since I live in OH) and set the cruise at 70. No drafting or other unsafe practices. Accelerate evenly. With the A/C running (always on Auto) I get around 32 on the highway.
City Driving
Usually around 26+ in the summer months and about 24 in the winter. I have learned that the key is slow to accelerate and maintain as constant a speed as possible.
All the above with those OEM Turanza EL42's (which I just replaced yesterday with Bridgestone Potenza 960RE A/S Pole Position).
Highway Mileage
City Driving
1. Cold Air Intake
1. Cold Air Intake
overinflating tires and riding a semi's ass = good way to f yourself up not to mention all the damage you get from rock chips.......
Highway Mileage
City Driving
Highway Mileage
City Driving
Registered Member
Yep. The 33.94 MPG I reported on this thread was when I still had the stock EL42's on the car. Those tires do a fine job for highway mileage (they should - they're Grand Touring tires), but not much good for anything else. When I installed my current tires in the spring of '06 (Michelin Pilot Sport A/S), mileage dropped to the lower 32's on the highway.. in general around a 1.75 MPG drop for city and highway. Rolling resistance was so noticeable that my car would not coast out of my garage with those tires where it did with the EL42'S.
Definitely off topic... TL or TL-S looks a lot better than TSX (which got hit with that 2009 Acura ugly stick!), has close gas mileage, has great power, etc, etc, etc. I'd gladly give up a tiny bit of gas mileage (worth maybe $100 a year lol) for all the other benefits!
I wonder why cruise contrl systems are designed to so diligently maintain the exact same speed up and down hills? They should be designed to slow down slightly up hills, this way it wouldn't need to burn so much more gas up hills.
Registered Member
Also, if it allowed the car to slow down too much, you could be opening yourself up to a traffic citation for failure to maintain speed and/or impeding the flow of traffic.
Unless you're driving in the mountains or a lot of hill country and/or are in 6th gear (manual), the TL cruise control does not "gun" the engine. The "sling shot" effect does not take place with this car. You tend to see that in 4-cylinder cars because of their lack of torque. The TL engine makes enough torque at normal driving RPMs to virtually eliminate this problem. The drive-by-wire is also more precise than a cable throttle and that is what is used with the cruise control system.
I am surprised no one has mentioned the need to manually calculate your gas mileage when filling up (gallons used divided into miles driven). The trip computer on the TL is much better than some of my previous cars as it is usually only about 1 mpg optimistic, but it has been off by 2-3 mpg a couple times.
This is how I calculate mine all the time. I don't trust the trip computer!!
Registered Member
But I will say the on-board system is a good one.
We have a Honda Pilot with a 3.5L version of this motor. When I set this on cruise (lets say 75mph), I notice the tranny will kick down on a moderate grade hill (not mountains). I believe the cruise is programmed to stay within a few MPH of set speed which is great on flat lands. I have noticed the TL will do similar behavior as well but I don't drive the TL as often on those types of roads. I'm sure the TL is less likely to kickdown in this situation compared to a heavier and less aerodynamic Pilot.
I'm just saying the cruise is less tolerant of speed variations in hills where I might be more flexible and let the speed drop maybe 5mph and save the kick down. In my example, I would drop to possibly 70 mph and be right in the speed range and not impede any traffic.
If you have the Trip Computer hack for the navigation, you'll see how much your instant MPG drops on a grade as well as a resulting kickdown of the tranny. Higher RPMs means more fuel consumed in this scenario. My general statement holds for people wanting highest MPG - avoid the cruise when there are lots of moderate hills.
joflewbyu2
08-18-2019 10:38 PM
ExcelerateRep
10-14-2015 08:20 AM
joflewbyu2
10-08-2015 11:16 AM
