Timing belt - low miles, lotta years
Hi All, I have an '04 that I purchased new in April of 2004. It has about 58k trouble-free miles on it at present.
Should I change the timing belt even though i'm way under the normal mileage? Is there a way of inspecting it and determining if it needs to be changed? Other than normal maintenance (fluids/brakes/filters), I haven't done anything else to the vehicle. Is there anything else I should think about replacing (spark plugs?).
Thanks in advance.
Thanks in advance.
AZ Community Team
Received 7,770 Likes
I changed mine on my '02 at 66k miles. It had 6 1/2 years on it. At that time I was told (and it may be in the OM) that the interval was 105k miles OR 6-years.
For the 3G TL I don't know without looking it up if the timing belt is listed as only a mileage interval or not. But, if it were me, I'd definetly think about getting changed in the 6 to 7 year range, regardless of mileage.
Change it.
the overexplainer
There is no time interval, only a mileage interval. Dealers, however, will say that it's recommended to have it changed at 7 years.
I'm at 60k here.
I'm at 60k here.
It's time or miles. Going past 7 years is the same as driving past 105k miles.
takin care of Business in
Received 4,732 Likes
Thanks in advance.
Thanks in advance.
Replace 3rd and 4th tranny pressure switches
Replace both air filters (I think you have done this)
Flush out tranny/brake/ps/coolant fluids (I think you have done this too)
I would also get the timing belt done....its 105K miles or 7 years...
7 years....so you got another year to save up for it LMAO !!!
what i did is, got all the stuff online (coolant/belts/tensioner/spark plugs/water pump) ~$300-400
installed the plugs myself and took everything else to the dealer...they charged me $500 labor...everything done in $800-900
....their initial quote was $1600....
OP - something to consider. What is your style of driving? My guess is that you are not doing a ton of highway. Mostly stop and go around town? That puts a lot more strain on your engine.
The TL has an interference engine. So if the belt goes you are basically screwed. If you have the cash I would replace it. Stuff breakdown over time as well as mileage.
Replace spark plugs
105K miles or 7 years....i got my tbelt done at 133K miles....its a risk and i wudnt recommend anyone taking it....
I concur![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I concur
The pressure switches I would only do if they are faulty or if I am experiencing issues. The timing belt I would change if I had the money.
As for the plugs I would consider my driving habits and in all honesty, they are not that expensive to replace.
Filter and coolant I would do. Brake fluid and ps is debatable unless there is an issue.
I'm sure his goal is to get another 7 years.
Everyone above me saying change it is right. You also have to consider where your TL has been. If you live in a real hot, humid, and salty place (FL for example). Definitely do it soon. Just remember that the belt is not made of stainless steel, it doesnt last forever.
What I said may sound dumb, but get it done for one main reason...
PEACE OF MIND!!!
There is nothin like a happy TL in harmony with a happy TL enthusiast.![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
oh and you should call around to local dealers, get prices, and make the closest one price match. The dealer closest to me quoted some ridiculous 1200 dollars. I found a dealer in SC that had a special for 600 bucks.
50 percent off?? I think yes. Here is the link... its old now but you get the idea...
https://acurazine.com/forums/3g-tl-2004-2008-93/%24585-105k-service-%40-acura-greensboro-nc-787669/
PEACE OF MIND!!!
If I had 7 years on the car I would do most of those. I would also have 300K miles on the car but that's not the point.
Changing plugs will make no difference in mileage or performance regardless of driving habits, and we aren’t speaking of a dead miss, only maintenance.
Brake fluid is to be changed every 3 years and if there becomes a problem with the caliper piston(s), it’s then too late.
How about reading the FSM maintenance schedule:
B4 Service-Replace timing belt. Note: If the vehicle is regularly driven in very high temperature over 110F, or low temperatures under -20F replace every 60,000 miles.
Now if you’re in a state that is regularly over 110F and/or under -20F the majority of the time, change it at 60,000 miles, but still no TIME limit.
Just don't know where all these iterpretations come from.........Maybe the Forum. Now, if someone has some hard evidence let's see it!
Owner's manual explicitly states 105k or 7 years, whichever comes first in normal / regular driving conditions.
Apparently the timing belt does have a 7year/105K miles service...if he has 7 years I would do it....
Pressure switches I would do since he has an 04 which are highly susceptible to tranny failures. I would do a $60 switch changes and $150 tranny fluid flush to prolly save me $3000 in a tranny....
PS fluid has a 60K change interval and since the OP is nearing that figure I put that in....
Coolant since the OP is doing water pump, its a smart idea to flush it out
Spark plugs, we know how fouled the OEM plugs get....not knowing the driving conditions/habits/etc the OP is in i suggested this as another preventive maintenance...
Brake Fluid has a 60K interval.
Better read the FSM before offering advice, and also do some research on plugs.
AZ Community Team
I know the 2G TL-S OM specifically says 105k miles OR 7-years, whichever comes first.
BUT my 3G TL-S OM does NOT. It only gives the MID code and NO time OR mileage limit; not even in the notes or fine print.
So, my question to you is: What year(s) 3G TL Owners Manual specifies a time and/or mileage interval?
the overexplainer
MyAcura.com's warranty section on our car also says in fine print "3.2-Liter V-6 Engine No scheduled tune-ups required for 105,000 miles***"
![](http://i17.photobucket.com/albums/b52/ez12a/Acura.jpg)
no time limit given.
AZ Community Team
Tune-Up Interval: 100,000 miles or more***
*** Does not apply to fluid and filter changes or periodic inspections. Exact mileage is determined by actual driving conditions. Please see your owner's manual for more details.
My question, though, still remains. Majofo say the Owners Manual specifically says 105k miles or 7-years. I'm wondering what year(s) that applies to.
I'm wondering if there are diffences in the maint schedule for differnt years. Maybe it's one thing for '04 - '06 and another for '07/'08. ??
I have an 04 with 83000 miles. I too had the same question. My manual does not state anything about years, only 4 on the MID. I was at the dealership this weekend and was told specifically to wait for the MID to give the 4 sub code, so that's what I will be doing.
As for the plugs, are you saying that replacing plugs will have no effect on mileage and performance? Are you also of the opinion that excessive stop and go driving or a lot of heavy idling will not degrade plugs faster?
Mine is different (I assume all '07/'08's, but not sure):
All 3G TL's have the same instructions, 4- service and no time limit.
Certainly would like to see where the manual explicitly states 105k or 7 years.
There is no mileage on the brake fluid as it’s every 3 years.
i know you are going by the maintenance minder in he owners manual...when i was at the dealership, they gave me another booklet which had the interval of all the services with time lines...I made an excel sheet using that with my driving habits/conditions/miles a year and I have been updating that spreadsheet since....Let me try to locate that booklet, scan it and put it on here....
Our 2008 knock around car called for an oil/filter change, air filter along with a fuel tank filter at the 30k mile interval, maybe $37 out of my pocket, but the dealer’s service listed in the waiting room for the 30k mile service was $570 that contained a list of non essential services/parts. Just throwing money down the drain, but the dealers love ‘em.
Enough said, so just do the services that make you feel good.
That was an acura booklet ![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
but yeah you very well could be right....i would go with my maintenance schedule and you can go with your/Acura OM....i know I might be shelling out $300 (tops) per year more but i guess its worth it....my car still drives like it used to 4 years back....
Am sorry for my misinterpretation in the thread....i was not trying to share/give wrong information, just what I do to my car.....
thanks for the all responses. I will be shopping around for quotes on a TB replacement, having just bought a new Ody I need the TL to last at least another 5 years (until the Ody is paid off!)
I am in almost the same situation as you: 04 TL 6M with 54K. I called Acura Customer Care and all I could get from them was "Follow the MID". Checked with multiple dealerships and Surprise, Surprise: they all recommended the TB service due to time. I have decided to go ahead and have the TB service done. May be a waste of money but I am just not convinced you can ignore the time factor on a TB. For me, it is worth the peace of mind. I will have my independent mechanic that does all the work on my S8 take care of the TL. The closest Acura dealer wanted more than $1K so it is worth shopping around. Good luck!
the mid has no way of telling you the condition of the timing belt. I'd like to hear from mechanics who've worked with low mileage hondas with lots of life. Have they seen one crack from the years and not the miles?
Indicates nothing to me since I dont trust any stealerships! I guess we all should do what you think is right for your car. If you want to do the TB service at 7 years, go for it. If you want to wait it out to 105k, then do that.
AZ Community Team
.... I have decided to go ahead and have the TB service done. May be a waste of money but I am just not convinced you can ignore the time factor on a TB. For me, it is worth the peace of mind. I will have my independent mechanic that does all the work on my S8 take care of the TL. The closest Acura dealer wanted more than $1K so it is worth shopping around. Good luck!
One of our vendors (Tim aka AcuraPartsGuy, iirc) was running a special on parts for the TB service including the water pump for, again iirc, $299.
If that's still going, it's a great deal. Basically parts at wholesale cost and no shop mark up. Just pay labor for the install.
(edit: heres the link to the group buy https://acurazine.com/forums/3g-tl-2004-2008-93/timing-belt-special-still-going-strong-%40-%24299-shipped-819990/. And it's Kaleb aka wholesalepartsguy; sorry about that.)
My
A LOT of people on this forum (myself included) say, "Follow the MID!", but then selectively deviate from that. AT pressure switches are a great example - there is NO service interval listed for those.
My
: It can't be a bad thing to change the TB at ~7-years. It may not be completely, 100% necessary, but it won't hurt anything. I also believe that parts age with time alone and this is a preventative step just to be on the safe side.
I agree that parts age over time, and I also think that most manufacturers assume that drivers average 12000-15000 miles a year and the mileage intervals are set up with that in mind. For someone driving as little as the OP I think it is something that needs to be considered.
