..for those with KAIXEN HID KIT (Fogs)... question
Real quick... figured i would get much quicker, better results on this forum
i just got my Kaxien H11 HID kit for my fogs...and i noticed it didnt come with any relays, just an upgraded 20AMP fuse to replace my OEM foglight fuse
Does anybody have this setup in their 3G Type-S ?/ Its primarly the same bulb/kit as the 4G....
my last texon kit, i had run an independent relay for each fog.... just wondering if i should order relays now so i have them on saturday, or just use the 20AMP fuse
Thanks!!!
Thanks!!!
Being an Acha Bacha in
You don't need independant relays.. you can just use one relay.. just make sure its a 30 AMP and you're good to go. If you wanna use individual.. then 15AMP each side but totally unneccessary.
I wouldn't suggest using stock wiring and just upgrading the fuse because over time you will burn the wires out. Remember ... during the first 5 seconds of boot up, it draw some hefty current.. through those skinny wires.
BTW Bosch is one of the better relays. If you need a pin out diagram for the relay let me know I might have one but I'm sure you know what the hell ur doing.
InFaMouSLink
10-27-2015 06:51 PM
oyayjoe
09-12-2015 04:40 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
