Stuck need some help really quickly
im trying to remove the intake runners, i got the ijectors out and i removed 3bolts in the front and two in the back but the one in the top left corner i have no clue how to get to since the wire harness is in the way...
please can someone give me some guidence
You need to detach and move the harness. Take your time and do it properly because cracking/breaking a harness or pulling a wire loose out of a harness by pulling and tugging can cause problems. It takes more time than anything. If you are a bit uncomfortable with it bust out with your phone or camera and take lots of pics. They helped me when I did the same.
takin care of Business in
Received 4,732 Likes
^^^ this
you need to make sure the harness is out of the way and take your time doing it....
also putting it back is gonna be a bishhhh....to put the fuel injectors back put some engine oil around it otherwise they will not go in....
I did it without removing the harness. I used couple of 1/4" extensions which gave me just that angle i needed cause of the play between each extension . I saw the bracket and the bolt holding it. I had to push the rachet trough one of the pulleys to unscrew it a little bit to have some play in the harness. Removing that bolt, if i did do it i dont know how i would have put it back in there. So i didnt take the risk
