Steps for converting a DVD video concert to a 5.1 DTS CD that the TL can read
Old 03-02-2004, 08:29 PM
  #41
Salden's Avatar
Originally posted by Lore
Let me verify -- you have static when you use WinDVD to listen to the .WAV files, right? You're not playing back the resulting CD-R that you're putting into the car, right?
If that is correct, then your conversion process is causing the static and it is not the TL's stereo that has a problem decoding as your software decoder is having the same problem.
Sorry, bad choice of words... yes, wav file just hisses when playing in windvd, haven't tried with burned cd (those are all in the car) but I am burning more tonight so I'll test. Either way, if this turns out to be a flaw in the player, is there any chance enough people play dts cds that this would ever be fixed?
Old 03-02-2004, 08:57 PM
  #42
CEO, Team Anthracite
Lore's Avatar
I think I made a mistake about the files -- if it just hisses it may be that WinDVD can't actually play the .WAV files as DTS files and you have to burn them to CD first (per svtmike's posting and my follow-up)
Old 03-03-2004, 08:24 AM
  #43
Salden's Avatar
I read on WinDVD's site that only windvd platnium can decode dts. Funny, I have a version that came with my motherboard and has the dts logo right on the gui but no dts decode? Odd...
Old 03-03-2004, 12:45 PM
  #44
svtmike's Avatar
Received 3,864 Likes on 2,031 Posts
That is true; I've got the Platinum so the decode works fine on my system.
Mike
Old 03-03-2004, 12:52 PM
  #45
Raheel's Avatar
Is it possible to take normal songs and put them on a DVD-A, and have TL recognize it?
So instead of 15-20 songs per cd, u can get about a 100 ?
Old 03-03-2004, 01:38 PM
  #46
Lore's Avatar
2004TL:
Not without DiscWelder or a comparable program.
Old 03-03-2004, 07:18 PM
  #47
zon76's Avatar
I'm convinced now that the noise (imagine a nail scratching against glass for an instant) is a result of the dts decoder in the TL. It is probably poor or non-existent error correction as svtmike suggested. After almost 2 hours of cumulative listening on my home system I heard zero noise spikes. The average interval between noise on the TL using the same CD was 1-2 minutes.
Old 03-03-2004, 07:28 PM
  #48
Lore's Avatar
And the poor error correction _could_ be chalked up to bad media (at least bad media in the sense that the TL doesn't like it)... so try a different CD brand and see if the same .WAV files cause screeches.
I had a few screeches on one of the CDs I made which never came back after the first time. I guess it just didn't read it right that one time.
Old 03-03-2004, 07:34 PM
  #49
svtmike's Avatar
I've found differing performance even among CD-R's of the same brand. I've tried slowing the burn speed down to 4x, none of it has made a difference for me.
Homemade DVD-A's on the other hand work great.
Mike
Old 03-03-2004, 11:08 PM
  #50
Salden's Avatar
Right Mike, regarding dts cd, I don't think it has anything to do with the media or burn speed. I think it's all about the encoder. Can we try this with something besides surcode?
Old 03-03-2004, 11:11 PM
  #51
svtmike's Avatar
I still think it's the error correction.
I made two different copies of my Henley disc onto CD-R media of the same type. The noise occurs at different places on each.
Mike
Old 03-04-2004, 12:39 AM
  #52
creamy-nuts's Avatar
man i cant even find SurCode, or even DiscWelder.
Old 03-04-2004, 12:48 AM
  #53
svtmike's Avatar
You won't find DiscWelder unless you buy it. Minnetonka has software dealers that sell it for less than list; I got mine from www.audiomidi.com.
Mike
Old 03-04-2004, 10:43 AM
  #54
270: Dats a lot o' horses
BTW - I emailed Minnetonka yesterday about the status of Discwelder Bronze and they said it will be available LATE March.
Old 04-01-2004, 02:57 PM
  #55
TL hacker
Zeuser's Avatar
Moderator: Sticky this please!
Old 04-01-2004, 04:48 PM
  #56
brusie's Avatar
would any of you guys who have all the equipment and can do this successfully be interested in making a few bucks? I have some dvd concerts i'd love to have on dvda, but can't afford all the equipment. I don't know how exactly we can do it, but if you're interested send me a message and maybe we can work something out.
Old 04-01-2004, 09:10 PM
  #57
Lore's Avatar
My understanding of DTS WAVs are that they are WAV files encoded using the DTS algorithm. As such, why is it not possible to burn that onto a DVD-A? Isn't the WAV still a 44.1 khz 16-bit file? Won't the TL be able to decode it?
Or is it because when playing creating the DVD-A, even the cd quality WAV files are "expanded" to 5 channels (2 channels of music, 3 channels of silence) -- I'm a little confused.
Old 04-01-2004, 10:45 PM
  #58
svtmike's Avatar
DTS .WAVs are exactly what you say - WAV files encoded using the DTS algorithm. The only way to burn that onto DVD-A is to decode the DTS .WAV first into five monophonic .WAV files, and then put those onto DVD-A.
The DVD-A spec only supports two types of coding of the bitstream it reads off of the DVD - LPCM and MLP Lossless Compression, which just decompresses on the fly into LPCM. DVD-Audio players do not support the detection and decoding of a DTS bitstream off of a DVD-A disc as a result.
There is a standard level matrix for "downmixing", or playing 5.1 sound through stereo speakers. There is probably a corresponding level for "upmixing" a stereo signal through a 5.1 setup, to ensure that the subwoofer level is proper when the L/R channels are split across the front/rear speakers.
The TL can decode DTS .WAV files, but only if they are burned onto a CD in redbook audio format.
Mike
Old 04-02-2004, 02:15 AM
  #59
Lore's Avatar
Thank you for your very detailed response. Hopefully USPS Priority Mail will come through and deliver my goodies tomorrow so I can mess with it. I played around with the demo and am not too excited about the interface but I can live.
Old 04-02-2004, 07:24 AM
  #60
sfintel's Avatar
Mike
I don't think you are correct here. I have a DTS encoded DVD-A (Porcupine Tree In Absentia) that is proof. See http://www.dtsentertainment.com/dvdaudio.php for a listing of DTS DVD-A's.
Old 04-02-2004, 07:36 AM
  #61
jdl75's Avatar
HEY SOOPA!!!
Can we make this a sticky or post it at the top of an ICE forum? This is looking like something that will come up again, and again and again and, well, you know.
frozenpenguin and svtmike - thanks a bunch for all of your help on this topic. I look forward to trying this when i finally get mine.
Old 04-02-2004, 09:07 AM
  #62
jrapps's Avatar
Has anyone here tried to convert an SACD to DVD-A or a DTS-CD? The slection of DVD-A discs isn't that great yet, but my local Best Buy seems to have a much bigger selection of SACD.
Also, when using discwelder (which I just ordered...waiting for delivery) to make a DVD-A using 6 wav files, does this mean that the total capacity of the disc is about 90min? A dvd holds about 6.7 times that of a CD, but there are 6 channels, so it balances out, right?
Thanks,
Jason
Old 04-02-2004, 11:26 AM
  #63
WayTooManyAcuras
oblio98's Avatar
Hey guys,
There is a whole underground community of folks who do DTS conversions of old '70s quad recordings. The guy who started it all has over 400 titles available. You can check his list out at:
http://hometown.aol.com/matrixquad/list.htm
There is also a community www.quadraphonicquad.com that has a forum (which you have to join to access - no charge - no fee) with a seperate section on DTS CDs and DTS conversions, as well as a DVD-A section with info on upcoming releases and reviews of players and software.
BTW - The Acura TL is the official car of QuadraphonicQuad!!
If you are into this stuff, it's worth checking out.
:-jon
Old 04-02-2004, 06:25 PM
  #64
svtmike's Avatar
Those are DVD-A's by DTS Entertainment. I even have a couple of them (Queen's The Game and A Night at the Opera).
Those discs (the Queen discs I have, not the entire DTS Entertainment catalog) feature 96kHz/24 bit DTS encoded tracks in the DVD-V portion of the disc, but the DVD-A portion is Advanced Resolution MLP encoded.
Mike
Old 04-02-2004, 06:44 PM
  #65
sfintel's Avatar
Mike
I just had another look and you are correct. There is a 5.1 (24/48) MLP encoded group as well as a 5.1 (24/48) DTS and 2-channel groups.
Old 04-02-2004, 06:46 PM
  #66
TLover's Avatar
If anyone is willing to convert some concert DVDs into DTS-encoded discs I'll glad pay for your services.
mada51589
05-03-2022 08:54 PM
jamestheunderdog
07-19-2016 07:58 PM
BoricuaTL
04-08-2016 01:08 PM
12-13-2015 02:21 PM
bymotion
11-18-2015 11:28 AM
Quick Reply: Steps for converting a DVD video concert to a 5.1 DTS CD that the TL can read
