SR7 Install
321 whp SAE
SR7 Install
I switched the VSA button and the blank panel for the LED so I can see it while driving . Only thing is they are shaped to fit the orginal spots so they don't fit perfectly. I might change it back.
Here's another shot of the LED. This picture is distorted because the LED is flashing and I took the picture at that moment
The display unit I put in the top compartment.. I didn't drill a hole to route the wire. The compartment is actually 2 peices that you can lift a part just enough to slip the wire through. Wrapped the wire of course with heat shrink to protect it
I mounted the radar sensor behind the grill.. Would have liked to have the unit higher but this was about the only spot to mount it nicely.
A closer shot of the sensor
I put the wire through the firewall using an existing hole.. It is just about center of the firewall. There is a little rubber grommet that has to be removed from the engine. It is a little tricky, but use a flat head to do it. On the inside you have to reach up towards the center of the firewall up and to the right of the pedal. There is a pre-cut circle of removable sound deadening material that can be moved off to one side for the wire to come through. All in all it was an easy install that took some time.
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
