Sneek peek at my fog relocation mod.
#42
Wow car still looking sexy hell Gus.... Ohh by the way i'm the guy who bought your original painted headlights from your tL in the bx... Finally got on acurazine ... Lol... Keep up the good work !
Undying Dreams (11-28-2012)
#46
I have this same harness, does anyone know which colors go where yet?
Sorry to hit up this thread too, but i just need some help to install my foglight.
The harness is a little differnt then the oem stock ones, so im a little but confuse what wire goes where. I got my foglight off ebay and the quality is pretty good.
Can someone help me as to what wires goes where?..Please![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
![](http://i123.photobucket.com/albums/o309/Tony4681/f2.jpg)
#55
35 watt hid bulbs are cooler compaired to stock bulbs. Yes the lens will still get hot but not as hot as stock bulbs. There are other members on this website that have done this mod and I believe are running hids. So far nobody ran into a problem. I did have to trim the platic legs on the hid bulb so that it fit into the housing. I know others had the same problem. I used some gasket maker and sealed up the back side so nothing gets inside the lens.
2nd off this mod isnt really for function. YES it will light up the road, but no it wont be as good as an 07 fog system. We mod our cars to our liking because we want to look different from the rest or at least better than stock. I know so many people on this forum that want to do the same mod but its like a 50/50 some want it for real pure function others for looks.
#57
Which wires are not used from this harness? https://acurazine.com/forums/3g-tl-2004-2008-93/accord-foglights-relocation-help-622781/ there are 3 wires that stems out from the foglight harness plus the brown connector. Also on the switch harness there are more wires that aren't used? any help please! thanks!
#58
iWhine S/C 6MT TL
Which wires are not used from this harness? https://acurazine.com/forums/showthread.php?t=622781 there are 3 wires that stems out from the foglight harness plus the brown connector. Also on the switch harness there are more wires that aren't used? any help please! thanks!
#60
Read my write up and you will see what wires are not used. However as I told another member It's been a few years since Ive done this mod so to figure out where the inline fuse connects would be simple if you temporary setup the kit and use your battery as power & ground make all your connections and start using the inline fuse connected to the battery and touch the remaining wires to the foglight harness.. Eventually it will light up, and that's the wire you use. I'm sure other members can verify which wire is used with the inline fuse who have the oem accord kit. If I find my orignal paper where I wrote down how the harness connects I will finally answer the inline fuse wire question.
#62
2006 TL: WDP/Ebony
kopau, I know you just did this..can u help me out here..this is for oem accord setup.
hey guys, anyone doin this..I am having some wiring problems..this is what I have so far..
fog harness
black: ground,
blue/red stripe: inline fuse to fusebox power (10mm)
brown connector: green wire tap into thur fire wall to swtich green wire.
black relay plug into brown connector, grey relay to other connector (blue)
switch harness
green wire from brown connector to green
black to ground
blue tap into park light source (red/black strip)
here is the issue: with park lights on, switch lights up but no lights on..
when I swap the relays, lamps come on without park lights on .
thanx
fog harness
black: ground,
switch harness
black to ground
thanx
#63
2006 TL: WDP/Ebony
^never mind I got it..everything was right, my problem the ground was weak and the trigger wire for the relay (green) was not a good connection.. ie tap not making contact.. anyways thanx AZine members..
#66
awesome info
i might consider install the HID fog now if it doesn't heat up like the original halogen bulb... more question... does the HID bulbs draw more current or power than the halogen bulb? does it take more wattage? the reason I ask is because I'm running both set of fog lights from the same original wire... the wires were spliced and shared on these fog lights... Thanks
Here is my setup.... an old pic...
![](http://i170.photobucket.com/albums/u272/psheu/DSC02899-rd.jpg)
#67
Help Please
This is how I have my OEM accord fog lights wired, I get a light on my switch but nothing from bulbs.
Relay:
Black to Ground
Blue/Red to inline fuse with 20a fuse to bottom 10mm screw in fusebox
Green wire from brown connector to green wire from switch
Blue wire from brown connector.....Nothing?
White/green....Nothing
Red/Green....Nothing
Switch:
Green to green from brown switch
Red/Black to parking light wire
Blue to parking light wire
Black to ground
Red to ground
Relay:
Black to Ground
Switch:
Black to ground
Red to ground
DerrickW
11-15-2015 05:52 PM
