Should I sell my Auto and get a 6MT?
#41
I don't live in Calgary... Just visiting for the holidays
I have been driving on all seasons in the TL for 5 winters. I will be fine.
#42
All seasons with one wheel drive, must be fun.
Loving the limited slip differential 2 wheel drive on winters, so fun and so confident. I don't understand why they use open differentials on any car...
#43
ok back on the topic OP. Good luck finding a clean TL-S MT unmolested, if you can find one then get ready pay premium price for it. If I ever buy a MT TL-S it would be 100% stock.
#45
Now I am thinking I am never one to go withthe crowd or let other opinions dictate my decision making.... Will probably keep my auto and buy another auto when its done. I dont need to "feel the road" or "feel connected to the car" etc....
#47
OP take it from me, I absolutely love my base, which is why I've decided to keep it.
However, after driving the 6mt, I have fallen in love all over again. It's not only about it being a type-s in 6mt, to me its about the subtle differences and really getting to know the car.
I have only done a fluid change and some tint to the car right now, but as mods progress, so will my love. Driving a 6mt is a totally different experience, I would not change it for anything (seriously).
Keep on the hunt for one, it took me about 4 years to find the one I'm in right now....I did come across others, but the condition was absolute crap and the owners had not appreciated the car.
Good luck!
Good luck!
#48
I don't know how I would do that. I also would not want to mess up someone elses transmission being that I am more of a novice stick shift driver. Like I said earlier... I have no problem driving trucks but cars have given me problems at my experience level. If I were to get one I would probably get the owner to drive it around with me in the passenger seat. If seemed good I would proceed from there... If I bought I would be wrecking my own manual tranny lol
#49
Good luck!
Good luck!
What makes it harder is the fact that Caandian TLs go through much more salt for longer periods of time due to our more substantial winter weather and this would cause more corrosion/rusting on these now older vehicles... I would probably need to find one that was garage kept and put away for the winters to make the purchase worth the time and money... It would likely cpst more but it would probably be worth it from wbat I gather....
#50
Maybe learn on a beater OP. I've driven nothing buy manuals, with my base being the only exception. The type-s' are a bit finicky in first gear, but this can be easily resolved. I agree that learning on a type-s will probably cause more harm than anything. See if someone you knows has a beater, if you can refresh your skills, driving a 6mt type-s wont be an issue
#51
If you can drive a truck stick, there isn't much difference in the operation of a clutch in a car. As mentioned the TL is different than most cars but the learning curve isn't bad at all.
If you are even slightly interested in a 6MT, you should definitely test one out. I'm sure you'll be fine & it takes a good shit kicking to destroy a tranny
#52
#53
It is different because it is a self-adjusting clutch. Its not a bad thing it just takes time to get use to. When I had to replace my clutch I switched it to a clutch from XLR8 and it has been easy to drive since. I do daily drive my TL and I don't regret going from an auto TL that needed a new tranny to a stick TL TypeS.
#55
Here is my dilemma right now buying a TL-S MT, if I ever get a MT TL its has to be the Type Slow. I only wanted two color combo possible in 3g TL (which is the rarest) KBP or MRP with two tone seat. if I ever found those two color with clean condition most likely I am looking at $16-$18k, for me that number is ridiculous and here why.
I paid sub $20k for my TL-S 6 years ago and now you asking high $10k? I mean I would understand if the car been well keep and maintain with 60-70k miles but mostly they around 105k miles if not more.
OP the reason why AT and MT TL is so drastically difference because in the MT you will feel the full power of the J35A8 (TL-S) this is possible because the gearing in the MT is much more aggressive than the 5spd slush box counter part. If you get a chance to test drive MT TL, the money shift which put a smile on your face is between 3rd to 4th or vice versa. RPM only decrease about 1.5k-1.7k which you fall right into max torque band and top end of the Vtec and engine pulling strong all the way to redline. You have about 5 seconds to shift into 5th gear where the auto took 20 years to reach redline. Also the MT unit is about 125-150 lbs lighter than the slush box and in the MT there is minimal power lost compare to AT do to fluid moving clutch packs.
Dyno number doesn't lie either
TL-S AT 225-230 WHP
TL-S MT 250-258 WHP
Both being 100% stock
TL-S AT 225-230 WHP
TL-S MT 250-258 WHP
#56
Oh yes the check valve.... Hmmm.... Maybe it would be good for me then at the beginning? I wont be doing any days of thunder impressions for at least the first while anyway...
The wheel horse power makes sense... Doesnt the torque converter waste some power too when not engaged?
#57
i took the check valve out; and while better.....the car is still hard to get out of 1st gear. and Ive had the car for 8 years now.
it's gotta be the self adjusting dual mass flywheel BECAUSE the clutch is NEVER consistent with bite. in a span of 5 mins, it could bite low and then it could bite a little bit higher...(I have a new factory clutch in.)
I want to get away from the Dual mass flywheel and head into a more conventional clutch + flywheel
#58
Really? My clutch grabs the same every time..
I thought the self adjusting clutch was to keep the clutch grabbing the same as the clutch wears out? The dual mass flywheel most def plays a part of it.
#59
Mr. Detail
You said you had other vehicles and this is your fun car, so why not just buy yourself a sports car? A true two seater with rwd and a good LSD would be a lot more fun in the corners. Or maybe an AWD turbo car. Just my opinion, but if it would cost more than a 1000-2000 to get out of your TL and into the 6mt and youre going backwards in years that is not worth it. Manual transmission is fun, all of my cars except my first were manual, but selling an auto to buy a manual is not financially reasonable for me.
If your heart is set on a TL, then might as well get a 6 speed TL-S.
#61
i've found that seating (I have short legs, i'm chinese...okay..) plays a BIG part in how well the car shifts.
and ive learned it's okay to slip the clutch a little to get smoother, crisper shifts.
#64
Latent car nut
Two comments:
- @stevemk07; I have slightly different advice from other folks. If you want to stay happy with your current TL, do not under any circumstances drive a TL with the 6MT; it will ruin the experience of driving your car.
- @justnspace; I also have the factory clutch and will be replacing it with the full LUK setup (dual-mass flywheel, clutch, pressure plate, and slave cylinder with the deleted CDV); I do not experience any differential in the clutch engagement point from one shift to the next, and I'm trusting I will not when I replace the clutch. I'm wondering if there is something wrong with the hydraulics in your clutch assembly.
justnspace (12-29-2017)
#65
horseshoez (12-27-2017)
#66
Slot Machine Lubricator
i think it's a combo...
#68
This is what I have been feeling. Sometimes when I'm trying to pull away I notice the car is picking up and going like it normally does and I have to let the clutch out more. It bothers me because I always start wondering if I have the e-brake on, or did I accidentally put it in 3rd gear... But no, the engagement seems to change sometimes.
narrowing it down, it's gotta be the clutch rod adjustment.
the service manual states that you can adjust but dont adjust too far out!
as sometimes, the engagement point is HIGH, but then other times it feels like it grabs lower?
maybe I just suck at driving with three pedals.
#70
Mr. Detail
I bought the car used at 30k miles, had to replace clutch at 31k miles.
carlthegreat
11-02-2017 06:27 AM
