ShockSensor to factory alarm
You need an aftermarket alarm system- its the only way to get good protection
One that beeps the remote if trouble is worth having
Sorry for your loss- hope you have comprehensive insurance
Note to others- if you have special rims or other parts- have them added onto your policy so exact replacements- not OE replacements are used
What's the point of making your remote beep? So you can run-out to your car and get shot by the perps?
</sarcasm>
If you wanted to just add shock sensors and such, you just splice them to the hood-pin switch, becuase most shock sensors are not powered. They just close circuits when shocked.
You can probably get an electronic glass break sensor, and splice it into trunk switch/light, and mount the sensor on the rear deck. Electronic glass break sensors, (the kind used in home security), are powered devices, which is why they prob need to be mounted in the rear deck, so they can be powered by the circuit that powers the trunk light.
I had the clear corners stolen on my G35, so I bought some magnetic reed switches, (commonly used as door sensors in home security), and glued tiny rare-earth magnets to my clear corners, and mounted the magnetic switch in the bumper, and spliced it to the hood pin switch... So know if you try to steal my clear corners, the alarm goes off...
Oh yeah, I also replaced my horns with 139db air horns....
I never knew that..shud get that done
