Sh*t Gas Mileage
Ok, so I purchased a 06 TL in Oct. The first fill up I did with Super the car said "534 km to empty", I ended up getting about 430km, after that all the other fill up with Super I never got over 340km on a full tank, with regular gas I get about 270-280ish, thats with mostly city driving and easy on the gas and brake. My friend bought a TL one week before me and he gets about 450ish everytime on a full tank...I'm thinking about taking it in to the dealer to see if somethings wrong...or if someone can help me out here... that will be great -- thanks guys!
Sorry...dont understand all that km talk. lol Seriously.
At any rate...I have a blower and all the mods you see below and was screwing around with the trip computer the other day and noticed I get an avg 17 mpg - and its been running/tracking a LONG time...lol. This full race season in fact. So spring through fall of this year at a minimum about 50/50 track to street drive use...as I drive to the events. |
Oh sorry, i live in Canada so its in KM...my trip computer say i get about 12kmpg
340 km about 211 miles...
1 mile = 1.6 km
means your getting between 7 - 8 mpg comparitively. hmm...sounds like something is wrong there definately. Is it tossing any check engine lights or anything? |
Originally Posted by Starchyld
(Post 10287554)
.... all the other fill up with Super I never got over 340km on a full tank, .... mostly city driving and easy on the gas and brake.
My friend .... gets about 450ish everytime on a full tank... You 340/13.5 = 25 km per gal. (about 16 mpg) Your freind 450/13.5 = 33 km per gal. (about 21 mpg) Both of you have similar cars (both AT or both MT for example) AND driving similar routes and styles? 16 mpg is low, but I've seen others report 16 - 18 mpg in city conditions. I think most would say something like 18 - 22 mpg or 20 - 24 mpg is "normal" in the city. |
I have an 06 Auto and get ( per the on board which I reset every fill )
City 11L/100Km 19.6 mpg highway 8L/100Km 29.4 mpg Converter is here http://www.eforecourt.com/l_100km_mpg_convert.htm |
(Post 10287580)
It's low but not out of the normal realm. My city mileage averages about 17 and I'm very easy on the gas and I usually am able to time the lights so I don't use the brakes as much as most.
(Post 10287580)
Originally Posted by Jesstzn
(Post 10287828)
Thats more like 12L/100 Km the higher the red # the lower the gas milage . Thats about 19.6 / US gal or 23.5 for our gal.
Originally Posted by Majofo
(Post 10288288)
KM / Liter or KM / Gallon? .. he said 12 kmpg? I'm foncused..
I think he wrote it out wrong ... our display shows it as L/ 100 Km |
(Post 10287801)
City 11L/100Km 19.6 mpg highway 8L/100Km 29.4 mpg Converter is here http://www.eforecourt.com/l_100km_mpg_convert.htm My MID always shows 12L/100 Km (City Driving) |
(Post 10288323)
I still haven't found out if the computer puts "until empty" due to driving conditions or it holds back the 2 gallon reserve.. or if there is a reserve top off.. ?? idk ?? all I know is I can only put 13 gallons in when it says it's empty and I believe we have 17 gallon capacity. right? |
HAA if ur getting 8mpg that fuel is going out somewhere. Or u could be flooring the car at everylight going to topspeed and then hit the brake superhard jppp.:tomato:
i've had my 04 5AT TL since may and have i keep track of my mileage after every fill up. i also have the hacked navi with the trip computer that shows slightly different results then the regular one.
i started out filling up at any gas station with their premium, nothing less than 91 octane and then my friend with a twin turbo skyline who only ever filled up with 94 sunoco said he switched to shells' v-power 91octane and has gotten better performance and mileage. so i decided to give it a shot, why not and i get air miles at shell. after about 4-5 fill ups i started to notice a difference, i used to get almost 450-500km/tank and now i'm getting 500-550km a tank. the manual says my tank is 64.7L and the gas light comes on when there is roughly 15L left, i've taken it as far as 70km past the 0km left on the display with no problems. i've still never put in more than 60L in one fill up! i'm normaly around 10-11L/100km and have gotten as low as 8 with only highway usage. my gas mileage has gone down right around the time i got winter tires so i thought it was just that but then i checked my air filter and it was dirtier than a bums pocket. my mechanic is supposed to check that every oil change, clearly he didn't. your tire pressure and air filter are 2 things that can easily change your gas mileage. my suggestion is check both of those and try v-power for 4-5 fill ups and see if it helps although if you only get 340km maybe something else is wrong and you should have it checked. 340 is disgusting gas mileage unless you're driving a f-350 dualie |
Have you checked the Engine Air Filter? It should be replace every 30K Miles or 45,000 KM's. Use premium fuel and raise tire pressure to 35 PSI COLD. See if that helps. If not, buy a product called seafoam from you local auto parts store, and follow the instructions on how to use it here.
Originally Posted by TL|GTX
(Post 10288450)
Once again common sense > reading >>>> Tl|GTX. :tomato: |
19 miles per US gallon in heavy Toronto-area traffic isn't unreasonable. When I was commuting here in the DC area I generally got somewhere between 18 and 21 miles per US gallon with a commute of about 13 miles each way. I generally get anywhere from 27 to 30 mpg per US gallon when I do mostly highway driving, with the number varying depending on traffic jams, amount of non-Interstate travel, etc.
It's reasonable to expect that the average "highway" figure for many Canadians might be lower than for many Americans because of the lack of expressways (i.e., Interstate-style roads) in much of the country. My fuel economy in Nova Scotia this summer was a bit lower, for example. But in Ontario the 400-series highways are better than a lot of Canadian expressways, so that wouldn't apply to the OP. For the posters who don't follow the SI discussion, the US is the only country in the world to use miles per gallon. Most of the rest of the world uses litres per 100 kilometres driven (a more accurate measure of fuel consumption; our equivalent would be gallons per 62.5 miles driven, although you could use any distance as long as it were consistent), although some countries in Asia use litres per kilometre. The US miles per gallon standard measures distance travelled per amount of fuel used (higher number is thus better), whereas the European and Canadian litres per 100 kilometres standard measures the amount of fuel used per distance (lower number is thus better). |
(Post 10288450)
Anyway back on topic....16 mpg is pretty sad. Cold weather will have a big impact on your numbers so being your in Canada will cause this issue. I would put some Seafoam into a tank of gas and see if that changes it at all. |
Wow, get some respect and shut up mmade. I was replying to MichaelBenz 1 mile = 1.6 km
means your getting between 7 - 8 |
Respect needs to be earned little boy...........I think I can speak for most people on this site and say very little people have respect for you.
(Post 10289546)
means your getting between 7 - 8 You *do* know the difference between dividing and multiplying right? :tomato: |
lowest mpg i have ever gotten was 20 and that is due to snow and excessive stop and go traffics
Thanks for all the responses guys. I took the car into the dealership this morning, it was a hassle to get them to look at it because its out of the ordinary and they wanted me to pay $110 to run a diagnostic test, eventually I told them I'm not paying for that because the car has full warranty so they gave in. The mechanic came out 45 minutes later and told me it is out of the ordinary but the car has all the latest programs and nothing is wrong electrically or mechanically and its in good function. So, that was a waste of my time.
I put 3/4 tank Shell High Octane in the car last night, I drove to work and back (15km each way) and then this morning to the dealership, when I got to the dealership the car said 78km on the reader and the trip computer said 230km to empty, but I know I won't be getting 230, I'll end up getting something around 160-170. And, as far as your questions to help me solve this, when I purchased the car it had a full maintenance service done, fluids flushed, brand new tires, rotors, brake pads, air filters, oil change etc. and sorry for not making it clear I get 12L/100km according to the trip computer. The car is driven mostly 30km/day city driving to work & back and parked in my garage (which is the one of the warmest rooms in my house). Any other suggestions? I'm all ears :( |
First of all .. clear all the history of past milage ... and don't worry about "Km to empty" concentrate on L/100Km.
Km to empty is based on current historic driving habits and if it cold and stop and go it will be down. And if you watch it close you can add to it if your going down hill or coasting ... If after you clear it and then your getting something like 18L/100 KM then worry .. if its in the area of 9 to 12 for a short cold commute then its normal. |
when u first purchase the car it show more mpg but when u start to drive it it decreases therefore ur firend got a better mpg right now wait a couple of weeks and his will b the same depending on how he drives his car
Originally Posted by hmian00
(Post 10291157)
starchyld - what dealership did you go to? if it's acura of north toronto i won't be surprised, i've had terrible experience with them
i get 10 h.w. mpg on my tl can some one tell me why lol i dont go pass 3k rpms.. i do have a system thats about 200 pounds alonmg with 20 inch rims and a v2 intake. in the summer i use to get 300 miles per tank and now im looking at 210 per tank
Originally Posted by ac08odl
(Post 10293594)
Originally Posted by csmeance
(Post 10293751)
10 MPG on the highway??? How fast are you driving? Gear? In my 5AT I rev at 2.5K going 90 MPH and still manage to get around 25 MPG over a distance of 30 miles! 600 pounds can account for up-to a 5 MPG loss, but no where near 15. What tires do you have? Tread left? Air-filter replaced? Premium fuel?
(Post 10293751)
Originally Posted by RickyRatchet
(Post 10293340)
(Post 10290913)
Km to empty is based on current historic driving habits and if it cold and stop and go it will be down. And if you watch it close you can add to it if your going down hill or coasting ... If after you clear it and then your getting something like 18L/100 KM then worry .. if its in the area of 9 to 12 for a short cold commute then its normal. Ok so I cleared all the history yesterday. It started off at about 17L/100km, after I came back home the reader said 14L/100km, I'm going to drive the car today and see what happens, this is all city driving, didn't take it on the HWY since I cleared all the history. |
Remember that a LOWER number of litres per 100 km is better.
I bet they didn't even check the car, and just came back half hour later and said ur car seems fine, b/c u didnt pay them lol.
starchyld - i've tried no other dealerships so far, i bought the tl in may from north toronto and the sales people were pretty cool and nice. the service department's customer service is completely amateur imo. i live just south of them at yonge + finch, how about yourself?
(Post 10293843)
i only had my intake for about 5 months i cleaned it last month and checked all my tires and all of them are good(im running 45 psi on 20 inch rims). i swear to you im getting 10 pg.. im not driving fast at all i keep my car under 3k rpm...
Don't forget that prodigious use of the air-conditioner also has a significant impact on your fuel consumption.
