Retrofit '04 TL seats to Muscle Car
I have been looking through some of the wiring diagrams on this site for a while trying to figure this out. I have a 67 Chevelle and I have purchased 04 TL seats to put in it. I assumed this swap would be more straight forward but it seems the under seat control unit has thrown me for a loop. I basically just need to know which harness/wires to connect hot and ground wires to. I do not have the memory switch so I might be able to bypass the under seat unit. I have passenger and driver side with side airbags btw.. Any help will be greatly appreciated!!
What are you wanting these seats to do? I'm not sure how to make the functions of the seat work, but be careful with the seat airbags. The air bag connections are often wrapped in yellow loom to make them easier to find.
I just want the seats to adjust correctly as per each switch. I don't care about the memory seat feature. I have identified the yellow loom already. I guess I can start connecting 12v to the pins and see if I get movement...
you should probably try finding a wiring schematic; try online :shrugs:
