Replacement Radiator
just an FYI the Denso radiator on rock auto is the exact same as the one from Acura. Big price difference $65 vs $250. I just installed it and fit is 100% spot on.
Thanks for the info. I was aware that Denso makes the OEM radiator, but wasn't sure if it is a 1 to 1 fit. I have a Denso radiator sitting in my basement (also purchased form Rock Auto) that I purchased when I had a transmission cooler line leak that was repaired at a tranny shop. The repair has held up, but as soon as I see any sign that the leak has returned, I will be swapping out the radiator. How long did this take you?
I picked up a Denso radiator at Napa (I think) for my 07 TL a couple of years ago.....about $150 compared to the $450 that Acura wanted. Did it myself and saved a ton. Looked identical and working fine after 2 years and about 50,000 miles, but wondered if it really is the same. Time will tell.
Comparing Denso part number to Acura’s it was the same number. A visual they looked identical other than a few markings. All he connection points matched exactly - fan mounts, hoses, rubber vibration mounts etc. I’ll update here if I find any issues.
Nothing really beyond normal hand tools
drain coolant
undo two hoses
remove overflow tank
disconnect fan wiring connectors
remove plastic under car panels
unbolt radiator
remove radiator
install in reverse
drain coolant
undo two hoses
unbolt radiator
remove radiator
install in reverse
The following 2 users liked this post by BillMFD3:
DMZ (12-08-2017),
justnspace (11-30-2017)
DENSO >= OEM for price alone
Generally is most of the rock auto parts oem without the HONDA badge?
Head a da Family
Examples:
The LUK clutch kit from rockauto is the exact same parts that you get when you buy from an Acura dealer, A-La-Carte.
The O2 sensors are made by NTK, but the Honda branded versions cost at least 50% more, if not double.
The Aisin timing belt kit from rockauto contains the exact same parts as the Honda branded version, with the Honda version, you buy the individual components A-La-Carte.
When you buy the repackaged Honda version of almost everything, you're paying a premium for it to come repacked in a different wrapping, that's all !
There are occasional occasions where certain parts are exclusively from the dealer, and that should be the only time when you have no choice
My 2¢
