Replacement Axle Brands/Quality
Old Apr 10, 2016 | 08:19 AM
  #41
Taquila1's Avatar
Taquila 1
import direct @ Oreilly's it oem
Old Feb 3, 2019 | 11:37 AM
  #42
Joshua Pacheco's Avatar
5th Gear
Endless RPM
Anyone using the 500 hp endless rpm axles? How are they? Do they have a balancing ring ? Any issues? The pictures on the website do not look like the axles off the car. Would be cheaper route than oem if possible. 04 6mt
Old Feb 3, 2019 | 11:49 AM
  #43
mb.3g's Avatar
Late to the 3G Party
are you referring to the Insane Shafts' axles? If youre looking for a cheaper alternative to OEM axles they're your best bet. Buy them straight from the manufacturer.
Old Feb 3, 2019 | 12:09 PM
  #44
5th Gear
Everythung from the trans to the tires is new that spins the wheel. Intermediate shaft, tires, type s rims, both bearings, but the cv Axles i got from oriellys but have warrantied out for 3 different sets from same place and still vibration. My vibration is 65 and up. I need some inputs on what you guys think. Shouldve asked this first.
Purchased car with bent rims. Had to drive on it to save money for parts.
Old Feb 3, 2019 | 02:08 PM
  #45
nfnsquared's Avatar
...Purchased car with bent rims. Had to drive on it to save money for parts.
With that abuse, how can you be sure the axles are causing the vibration?
Why did you replace the axles to begin with? Because of vibration?
Old Feb 3, 2019 | 02:16 PM
  #46
5th Gear
bought car with bent rims ims couldnt afford new ones for while so had to drive it like that. Replaced rims and tires and road force balance and still vibrated. Replaced axles. Still vibrated did intermediate axle still vibrate. Warrantied axles 2 times after still vibrate. Im not abusing i baby that car and doing best to get it smooth.
please no judgement just looking for help and opinions.
Old Feb 3, 2019 | 02:22 PM
  #47
nfnsquared's Avatar
I'm referring to the abuse from the previous owner, not you.
You've now been through 4 sets of axles and the vibration hasn't gone away. Time to start looking for another cause of the vibration.
Old Feb 5, 2019 | 04:59 PM
  #48
jimmyfu's Avatar
LCA bushings. Had a slight vibration past 65+
Axle vibrations were more violent, and only happened when going from 20 -0> 25mph
Old Apr 21, 2019 | 07:18 PM
  #49
Bigpun1's Avatar
Originally Posted by AccordFlex
Insane shaft 500whp axles are what I am using. Overkill for some, but if you want strong axles they will do the job. Only $370 plus shipping too for both sides
How have the insane shafts treated you. I haven't heard of any other TL owners running them.
Old Apr 23, 2019 | 07:33 AM
  #50
DMZ's Avatar
DMZ
Head a da Family
I got mine from rockauto. 1 year so far and no problems. New not rebuilt, and cheap too! Installed by Paul, our miracle worker master mechanic here in North Jerzy.
Old Apr 23, 2019 | 02:30 PM
  #51
Bigpun1's Avatar
Do you know what brand? Did it have the balancing ring?
Old Apr 27, 2019 | 07:37 AM
  #52
DMZ's Avatar
DMZ
Head a da Family
https://www.rockauto.com/en/moreinfo...429130&jsn=331
Old May 3, 2019 | 05:21 PM
  #53
Richard1head's Avatar
05 tl M/T axles
Hey guys,
New to the forum. My car just hit 115k n needing to replace original axles along with suspension. Either going with tein street basis z or megan racing rx street 2. The problem I'm having is which axles to buy. Already did my homework on the raxles😥 has anyone heard of insaneshafts? Maybe other options?
Old May 5, 2019 | 06:21 PM
  #54
DMZ's Avatar
DMZ
Head a da Family
Originally Posted by Richard1head
Hey guys,
ROCKAUTO!
FWIW, My best bud from high school who owned an auto parts store for 25 years, and Paul our star master mechanic here in Nawth Jerzy BOTH recommend going with new NOT remanufactured drive shafts. I got mine from rockauto - new, cheap, and trouble free after a couple of years.
Old May 5, 2019 | 09:36 PM
  #55
Bigpun1's Avatar
ROCKAUTO!
Which ones did you buy from rock auto
Old May 6, 2019 | 05:38 AM
  #56
DMZ's Avatar
DMZ
Head a da Family
https://www.rockauto.com/en/moreinfo...429130&jsn=330
Old Jan 6, 2020 | 03:57 PM
  #57
Sparky16's Avatar
Replacement axles - recommended aftermarket brand?
To DMZ - your link above isn't working anymore, looks like RockAuto stopped carrying them now.
My 2006 AT right front axle is leaking grease a bit but no clicking yet, getting parts ready. Some folks posted a while back that they are happy with GSP axles from Advance Auto, but they no longer carry those, only have "Carquest New CV Axle shaft aasembly". Also had contacted Raxles for quote - $250/ea(with core return), plus shipping $60 for 1, $80 for both including return cost for core.
RockAuto currently carries APWI, Surtrack/Trackmotive and Cardone for new axles - can anyone suggest one? OEMs are $520 per side, don't want to drop that much on an 14 years old TL. Thanks for your help.
Old Jan 6, 2020 | 04:11 PM
  #58
horseshoez's Avatar
Latent car nut
@Sparky16, nope, RockAuto still carries them.
For cars with manual transmissions, you need these two:
For cars with automatic transmissions, you need these two:
Old Jan 6, 2020 | 04:32 PM
  #59
Sparky16's Avatar
For some reason, your link (and the DMZ's link) doesn't work on my PC.
Can you please just name the brand if it's allowed? Thanks.
Old Jan 6, 2020 | 05:04 PM
  #60
Sparky16's Avatar
Are they APWI brand?
Old Jan 6, 2020 | 05:14 PM
  #61
horseshoez's Avatar
Latent car nut
Yup.
Old Jan 6, 2020 | 06:09 PM
  #62
Sparky16's Avatar
Yup.
Thanks for answering that. Have you used these yourself?
Old Jan 6, 2020 | 06:51 PM
  #63
horseshoez's Avatar
Latent car nut
Yes, I have a 2006 TL 6MT and I've had these axles on it since August (well over 15,000 miles).
Old Jan 6, 2020 | 06:52 PM
  #64
Sparky16's Avatar
Thanks again!
Old Jul 16, 2021 | 07:43 AM
  #65
rockstar143's Avatar
@DMZ @horseshoez
Still going strong? I have a bad vibration from cheap axles and I'm not sure I'm into paying for oem axles at this point...
I found the APWI but they only have passenger side...which is the side I feel the vibration coming from but...Maybe I should
try raising the car up a tad to see if that helps.
Old Jul 16, 2021 | 05:01 PM
  #66
horseshoez's Avatar
Latent car nut
@DMZ @horseshoez
Mine are still going strong with over 30,000 miles on them.
Old Jul 16, 2021 | 09:00 PM
  #67
any idea why they only carry the passenger side one?
I feel like that's the side causing the bad vibration.
Thinking about raising the car up a smidge to see if it helps.
thanks @horseshoez
Old Jul 17, 2021 | 12:18 PM
  #68
guitarplayer16's Avatar
I bought APWI axles last year in June. Car drove like a dream. Four months later the driver side axle puked grease everywhere. Removed it and found a tear on the outer boot between one of the ridges. Filed a warranty claim with rockauto, which was useless because I would have got next to nothing back after shipping. Just bought another one for $85 (CAD) and still good.
Old Jul 18, 2021 | 04:49 PM
  #69
DMZ's Avatar
DMZ
Head a da Family
@DMZ @horseshoez
Still going strong after about 70K miles! Cheap, yes. Garbage no! What brand did you install?
Old Jul 19, 2021 | 02:12 PM
  #70
DMZ's Avatar
DMZ
Head a da Family
thanks @horseshoez
That's because they're out of stock on the driver side one. It'll appear again when they're back in stock.
Old Jul 24, 2021 | 04:12 PM
  #71
Okay well, good to know, thank you.
I ordered the APWI brand passenger side...I'll give it a whirl and see if it assuages my vibration for now...that's the side I feel it on anyway.
If it does me well I'll go ahead with the driver side down the line. I have seen raxles fail after 60K miles anyway so no point in spending the
extra scratch if I can avoid it.
Old Sep 18, 2022 | 09:43 PM
  #72
04ManualTL's Avatar
Time to raise this thread back from the dead. So how did it go? cause i got a vibration on my passenger side too.
Symptoms: shakes the whole front car like driving on rumble strips at slow speed. Under acceleration shakes anywhere from 55mph to 65mph then disappears at around 75mph+. Also, even under 55mph it shakes if i floor it from 0mph. if i dont floor it, driving normally it wont shake till 55mph-65mph.
Also I noticed if i have a passenger/s with me the car vibrates more dramatically, sometimes even sooner like at 45mph but still goes away at 75mph+. I would like to add i am lowered on coilovers for about 4 years now.
Thinking its the axles, I was hoping it was the rims cause i can just buy another one ez swap but i rotated the fronts to the back but the front of the car still vibrate like hell. It has to be the axles?
Might be my last time fixing this TL, yall see these new cars coming out? that toyota corolla gr.😍
Old Sep 18, 2022 | 10:06 PM
  #73
horseshoez's Avatar
Latent car nut
I have over 60,000 miles on my APWI axles and they are still as smooth as they were when I had them installed.
Old Sep 19, 2022 | 11:40 AM
  #74
I ended up going with oem.
Yeah new cars are nice but msrp and market adjusted msrp make me love keeping the old shit running
Old Sep 20, 2022 | 10:19 AM
  #75
TheSauceBoss's Avatar
I think I have about 50k on my APWis and they are also still running perfect. Well, technically one got tore apart when my lower ball joint failed, but that wasn't the axle's fault. I replaced it with another APWi. All have been smooth lol.
Old Sep 21, 2022 | 03:13 PM
  #76
BROlando's Avatar
Good to know that there is a viable aftermarket alternative!
Old Jun 14, 2024 | 01:34 PM
  #77
Chad05TL's Avatar
rockauto APWi's are like 50$. How are they so cheap? $50??
Can you swap/move the OEM damper to the new axles? (That round thing)
Is this a balancer? It is actually called a "dynamic Damper"
https://www.acurapartswarehouse.com/...1-s0k-a01.html
Old Jun 14, 2024 | 03:10 PM
  #78
With the APWis, you don't need the rubber donut/balancer. They are completely smooth without it. I doubt you'd be able to remove/add a ring to these axles anyways. You don't want that ring either way, since that's what traps moisture and salt that corrodes the axle and causes it to eventually fail. This is all assuming you are on stock suspension at stock ride height.
Old Jun 14, 2024 | 03:19 PM
  #79
Chad05TL's Avatar
what would stock ride height have to do with tapping salt and moisture ... vs. Not at the stock ride height
Old Jun 14, 2024 | 03:22 PM
  #80
Sorry if that was confusing, I meant that the APWis would be smooth as butter and a great replacement option IF you're at stock ride height. Lowered cars are typically harder on certain components, and I would opt for a higher quality aftermarket axle if you're lowered. The salt/moisture thing applies to all TL oem axles with that dampener, more particularly for us that live in the north where salt is used on the roads in the winter.
